building-scienceheader image
Will solar panel mounts cause roof leaks?
When Monica from New Jersey learned that her solar installer plans to drill 54 holes in her south roof, she wondered whether she should worry about roof leaks
Posted on Feb 4 by Anonymous
Our latest Question of the Week comes from a homeowner in New Jersey. Monica is uncertain of the best way to insulate the roof of a new second-story addition on her Cape Cod home. She wonders whether it's wise to insulate directly under the roof sheathingMaterial, usually plywood or oriented strand board (OSB), but sometimes wooden boards, installed on the exterior of wall studs, rafters, or roof trusses; siding or roofing installed on the sheathing—sometimes over strapping to create a rainscreen. — especially since the mounting system for her photovoltaic(PV) Generation of electricity directly from sunlight. A photovoltaic cell has no moving parts; electrons are energized by sunlight and result in current flow. array requires 54 holes to be drilled in her asphalt shingle roof.
Monica wrote, "Is spraying the roof deck with foam going to increase the possibility of a major problem down the road if a leak should develop? There will be 54 holes drilled for the solar mounting system, and even though the installer assures me they won't leak....well....of course they will say that!"
Robert Riversong pointed out that it makes sense to bring her attic inside the home's thermal envelope — especially since she has a furnace in the attic.
Martin Holladay pointed out that there are mounting systems available for standing-seam metal roofs that don't require roof penetrations.
John Brooks reminded Monica that it will be expensive to dismantle the solar array when her shingles wear out.
What do you think?
To read Monica's question and all of the responses it generated, see "Insulation options are of concern with solar panels."
Feb 9, 2010
10:56 AM EST
Twice as Many Members Agree
by John Brooks
as of today ....67% agree that Compact Insulated Roof assemblies are more problematic and should probably be vented to avoid problems!
Do you realize that we are taliking about 2 out of every 3 members! ;-)
*voting members
Feb 9, 2010
11:37 AM EST
Surge in Voting
by John Brooks
A recent surge in voting is swinging towards non-vented
Feb 10, 2010
12:06 PM EST
OK, Sorry about the joking around
by John Brooks
Consider a hypothetical .....there is only a 2% chance that a penetration might leak.
If there are 54 fasteners.....what are the odds that at least one fastener/penetration leaks?
of course I am just making up the 2% number
Feb 13, 2010
11:54 AM EST
apples and oranges
by Whetstone Green
I don't see what one has to do with the other. How does spraying the roof deck increase the likelihood of a leak? As mentioned by John, I would be more concerned about the difficulty (and higher cost) of future roof repairs.
The decision as to whether to encapsulate the attic comes down to cost vs. potential energy savings. Closing an existing vented roof can be expensive. The ceiling insulation must be removed and the roof vent system closed. And if the roof extends over a porch or garage, that portion should be blocked off, otherwise you'll have to seal off and insulate a larger area than necessary. It's important to align the air barrier with the thermal boundary.
In order to calculate potential savings, it's necessary to estimate how much energy that particular HVAC system (presumably there is more than one) contributes to the overall energy bill. It would be reasonable to expect encapsulation would save 10% to 15% of that system's operating costs. The percentage would be higher in mid winter and mid summer, and less in milder weather.
Finally, don't confuse conducted heat loss with duct leakage. The latter typically represents a bigger loss and is much less expensive to fix.
Feb 15, 2010
5:20 AM EST
The likelihood of a leak
Whetstone,
You're right — spraying foam against the roof sheathing does not increase the likelihood of a leak.
However, it complicates leak detection and leak location, leading many to worry that a small leak might cause sheathing rot before it is detected.
Feb 27, 2010
11:11 PM EST
Insulated Roof deck with a few inches plenum to vent
by Harry Zhou
I thought an insulated roof deck can be vented by creating a suspended plenum on top of the roof deck - perhaps a little additional material for an extra layer sheathing and some 2X purlin. But you get both insulated attic and roof venting. Isn't that what the 1st PH in IL did?
Feb 28, 2010
6:04 AM EST
Venting roof sheathing
Harry,
You're right, or course. It's possible to build a ventilated insulated roof with the vent channel on top of the roof sheathing. Such a design usually requires a second layer of sheathing, unless you use metal roofing.
Post new comment
The content of this field is kept private and will not be shown publicly.
Discussion policy: The editorial staff at GreenBuildingAdvisor.com does review user submissions. Please be respectful of others. Inappropriate content will be removed.
  • Web page addresses and e-mail addresses turn into links automatically.
  • Allowed HTML tags: <a> <em> <strong> <cite> <code> <ul> <ol> <li> <dl> <dt> <dd> <blockquote>
  • Lines and paragraphs break automatically.
* required fields
