Business is Great in Green Home Building and Remodeling
My 4th Commandment: Keep the faith!
December 2009: Signed design contract for green design/build/remodel, 40-year-old suburban home; $90,000
Profile: Energy auditEnergy audit that also includes inspections and tests to assess moisture flow, combustion safety, thermal comfort, indoor air quality, and durability., kitchen remodel, remedial HVAC(Heating, ventilation, and air conditioning). Collectively, the mechanical systems that heat, ventilate, and cool a building. and insulation work
Status: Nearing completion as an ANSIAmerican National Standards Institute. National nonprofit membership organization that coordinates development of national consensus standards. Accreditation by ANSI signifies that the procedures used meet the Institute’s essential requirements for openness, balance, consensus, and due process.
Bronze remodel; Performance Path
January 2010: Signed construction contract for a LEEDLeadership in Energy and Environmental Design. LEED for Homes is the residential green building program from the United States Green Building Council (USGBC). While this program is primarily designed for and applicable to new home projects, major gut rehabs can qualify.
home (Silver);
$601,000
Profile: 3,100 sq. ft., Energy StarLabeling system sponsored by the Environmental Protection Agency and the US Department of Energy for labeling the most energy-efficient products on the market; applies to a wide range of products, from computers and office equipment to refrigerators and air conditioners. everything, wired for electric car and PVPhotovoltaics. Generation of electricity directly from sunlight. A photovoltaic (PV) cell has no moving parts; electrons are energized by sunlight and result in current flow., spray foam and cellulose, standing-seam roof, VOCVolatile organic compound. An organic compound that evaporates readily into the atmosphere; as defined by the U.S.
Environmental Protection Agency, VOCs are organic compounds that volatize and then become involved in photochemical smog production.-free paints, PureBond cabinets, bamboo flooring
Status: Groundbreaking, July 2010
February 2010: Signed construction contract for major residential fire project; $240,000
Profile: Whole house gut, 60-year-old suburban home
Status: Bronze-level ANSI projected after August completion; Performance Path
March 2010: Completed remodeling of the “House That Love Built”; $440,000
Profile: Whole house gut, deep energy retrofit
Status: 1st Gold-level ANSI remodel in Texas; Prescriptive Path
May 2010: Completed design/build remodel of historic 1930s-era home; $120,000
Profile: Energy audit, master suite and laundry addition, kitchen remodel, HVAC, window and insulation replacement
Status: Silver-level ANSI remodel certification pending; Performance Path
Other Blogs in this Series
June 2010: Signed design agreement for whole house remodel, 40-year-old suburban home; $160,000–$200,000
Profile: Kitchen, two bathroom remodels, master suite addition, insulation and window replacement
Status: Expected start date, August 2010; Bronze-level Performance Path projected
June 2010: Signed professional services agreement for LEED Silver custom home
$550,000
Profile: 2,800 sq. ft., butterfly roof, very contemporary, Austin limestone
Status: Working through budget with goal of signing construction contract in July 2010
Bottom Line: There is green in green! I know you read about it every day, hear it at industry trade shows, see it online and watch it on TV, but you still wonder: When will it reach my hometown? When will I get a piece of that action? Keep the faith. That’s my 6th Commandment. Keep the faith!
Which means, when it arrives at your door, you need to be ready or you won’t hear the knock. You had better already have your green designations from the NAHBNational Association of Home Builders, which awards a Model Green Home Certification. or the USGBCUnited States Green Building Council (USGBC). Organization devoted to promoting and certifying green buildings. USGBC created the LEED rating systems.. You have to understand basic building science in your climate zone. You should be able to recognize the difference between a sales prospect that hugs trees and one whose sole focus is financial payback. You should know that premium green expertise means you mark your costs up, not down.
Since green building and remodeling are here to stay, you could argue there is plenty of time to figure it all out. But I’m here to argue, if you haven’t already signed projects similar in scope within the time-frame I listed above, you had better start rethinking your strategy, because the knocking on your door has already started. Green demand is here, and it’s here now! Keep the faith—these numbers are just around the corner for you, too.
Wed, 06/30/2010 - 16:49
Be on the train or be on the tracks
by Michael Chandler, GBA Advisor
Opening up here too. Design work is raging. Construction contracts still slow to convert.
Wed, 06/30/2010 - 18:35
Hope
by Christopher Briley
You're giving me that warm and fuzzy feeling that keeps the dark shadows away. Things are still sluggish up here in the north east, but I will keep the faith my brothers and sisters! Thanks for the blog post Michael.
Tue, 07/06/2010 - 11:26
The Thaw is Here
by But What if We Are Wrong?
With east coast expereincing Texas weather this week change will be on the way. Wacky waether will only benefir our businesses! But I honestly believe if we can get our "leadership" to step out the way we can turn this economy around and be just fine. Just need to send our US Congress and State Houses on an extended recess for the rest of the year so we can all get back to work!
Wed, 09/22/2010 - 16:29
Remodeling 40-yr-old houses Green?
by Pam
When is it "greenwashing" to say the remodeling a 40-60 yr old house is "green"? Most of these homes were quite well built to begin with. Is a $440,000 deep energy retrofit really "green". Is a 3,100 s.f. house "green"?
Fri, 09/24/2010 - 15:00
40 year old Houses
by Michael Strong, LEED Associate, CGP
I guess the best answer to that question Pam is another question: "WHY is the house being remodeled to begin with?" In most cases the 40 year old houses that we remodeled are anything but "well built". They might be lucky to have r-9 insulation in the walls, there will only be remanants of insulation left in the attic, none of them have radiant barriers for the roof, the appliances, windows and lighting are not even in the same league as the Energy Star counterparts now availble in the market. The water heaters have none of the efficiencies of todays tanked or tankless models. The plumbing fixtures are guzzlers that use 2-3 times the water of todays Water Sense certified fixtures. The duct work leaks like a sieve, the efficiency rating on the ac are single digit. Son on and so forth.
Bottom line is these "well built" 40-60 year old homes might have good bones and foundations but I tell our clients that when it comes to the rest of the home: thank goodness we don't build them like that anymore!
As for a 3100 square foot being green that sounds like a topic for another blog!
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Michael Chandler, president of
DINA LIMA (CGP, CGB, CSP, RCS, CAPS) is a Social Media Consultant, Speaker and Trainer, and CEO of
Michael Strong is President of
Comments
