How we s'posed t' get paid fer this green stuff?
It's not an UPGRADE; It's what makes us different from the competition.
I teach the NAHBNational Association of Home Builders, which awards a Model Green Home Certification. Certified Green Practitioner class, and it’s a wonderful gang of skeptics and beleaguered tough guys I’m faced with every time. These guys don’t sign up for the class until they’re ready and eager to learn, they want to build tighter, healthier, more durable and efficient homes. But they are convinced that the customer isn’t ready to pay for it. The bottom line is, they aren’t ready to sell it, and if they can’t get the contract signed at a price that supports the effort of stepping up to Certified Green building practices, this whole movement is dead in the water.
There are two themes at work here. First, green building is not an upgrade, it’s a differentiator. To a certain extent, "green" is just a handle that we put on durable energy- and indoor-air-quality—focused building. If you are a conscientious builder, you are probably pretty close to building green already. So when builders are just getting started on green certification, I encourage them NOT to try to build the next house green before finding out just how close to green the last house was.
We need to stop dancing around the discussion that you don’t want to have with our customer. “I can build you the very worst-performing, D-minus type, barely legal home (code minimum), or I can go green, but green will be more expensive.” We’re not going to have that conversation—you wouldn’t be reading this unless you’re already building a much better-than-code home because both you and your customers demand it.
So when you run the last house you built through the on-line calculator at www.nahbgreen.org, you are going to find out that, but for a few cans of low-VOCVolatile organic compound. An organic compound that evaporates readily into the atmosphere; as defined by the U.S. Environmental Protection Agency, VOCs are organic compounds that volatize and then become involved in photochemical smog production. paint, having a pizza lunch to get all the trades together to go over the plans before construction, a legitimate Manual J calculation from your HVAC(Heating, ventilation, and air conditioning). Collectively, the mechanical systems that heat, ventilate, and cool a building. guy and some CRI labeled carpet, you could have certified that last house Green and Energy StarLabeling system sponsored by the Environmental Protection Agency and the US Department of Energy for labeling the most energy-efficient products on the market; applies to a wide range of products, from computers and office equipment to refrigerators and air conditioners. just for the cost of the report cards. And the only thing that costs extra out of all that was the pizza, the Manual J and the report card.
Green isn’t an upgrade — it’s the way quality builders build houses. We would no more offer our customers discounts for letting us build to the lowest standard allowable by law than we would charge extra for building a house good enough to let us sleep well at night. Green-building certification is simply a way to put a meaningful number on just how well-built a home really is under the granite countertops and the fancy trim details. It’s what differentiates the good builders from the mediocre ones.
Back to the class. We had an experienced green builder there who was just banging his head against the wall. “I know,” he says, “but I talk to them about the HERSIndex or scoring system for energy efficiency established by the Residential Energy Services Network (RESNET) that compares a given home to a Home Energy Rating System (HERS) Reference Home based on the 2006 International Energy Conservation Code. A home matching the reference home has a HERS Index of 100. The lower a home’s HERS Index, the more energy efficient it is. A typical existing home has a HERS Index of 130; a net zero energy home has a HERS Index of 0. Older versions of the HERS index were based on a scale that was largely just the opposite in structure--a HERS rating of 100 represented a net zero energy home, while the reference home had a score of 80. There are issues that complicate converting old to new or new to old scores, but the basic formula is: New HERS index = (100 - Old HERS score) * 5. ratings and the blower door numbers and ERVs and low VOC everything we use, and their eyes just glaze right over.” This guy was so passionate and so frustrated. And I can relate; I’m a shelter nerd too — I think energy-recovery ventilators are just fascinating. My customers find this amusing, I think.
The regional marketing director from the giant national building company had the answer that makes the second theme for this story. “You’re trying to sell the features, when what they are interested in are the benefits.” Customers don’t really care what you do to make the house better than the one across the street; they care that you are conscientious enough to build them a home that uses less energy, is more comfortable, has cleaner indoor air, conserves water in times of drought, is more durable, and requires less maintenance on the weekends.
This is what “green” means to them. It helps if it gives them a warm and fuzzy feeling when they talk about how green their house is at the family reunion and if it looks like it will hold its resale value better than the energy hog across the street with the smelly carpet. But it’s about the benefits to their family, not the methods you employed to achieve them, and it’s the same for the small custom builder, the small production builder, and the national giant.
So we’re not selling green features, we’re selling differentiation and benefits. As green builders, we don’t just say we’re conscientious about the details, we prove it with third-party testing through Energy Star and a Green Building Certification program. We bring value through our green building systems and products, which have measurable benefits for the family that will live in this house.
Green building is not an upgrade (from brown to green); it is what differentiates your company from those who don’t care enough to build green. The customers don’t care about what you do to make their house green, they care about how living in a green house will benefit their family.
Image Credits:
- Leigh Scott, HBA-DOC
Wed, 05/06/2009 - 14:37
Gettin paid
by Carl Seville, GBA Advisor
Michael - You summarized it best in this line "it’s the way quality builders build houses". The most effective way I have explained the difference to people to date is using a car comparison. They can drive a Yugo, a Chevy, a Toyota, or a Lexus (or pick your personal favorites). Their homes are equivalent - basic barely code or lower is the Yugo, slightly above that is a Chevy, and so on. If they want to live in a piece of crap they are welcome to, but competent builders need to set their minimum standard at something above the Yugo and let their clients upgrade from there.
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Michael Chandler, president of
DINA LIMA (CGP, CGB, CSP, RCS, CAPS) is a Social Media Consultant, Speaker and Trainer, and CEO of
Michael Strong is President of
Comments
