GREEN BUILDING TIP: Design for Efficient Lighting
The right combination of task and ambient lighting can save energy
Task lighting fills in where ambient won't. Great daylighting in this house means the lights are rarely turned on during the day. In the evening, task lights above work stations—like the counter, the stove, and the island—make it easy to get the job done.
A mix of lighting sources allows you to use the type of light you need: task lighting for reading, food preparation and other activities — where strong, concentrated light is helpful — or ambient lighting where more general illumination is better. Not all lights have to be on all the time, and natural light can be a significant contributor when floor plans are designed accordingly.
—This GREEN BUILDING TIP is from our Strategy Generator. Build a tip sheet for your green building or remodeling project under the Strategies & Details tab.
Green Points
LEED for HomesLeadership in Energy and Environmental Design. LEED for Homes is the residential green building program from the United States Green Building Council (USGBC). While this program is primarily designed for and applicable to new home projects, major gut rehabs can qualify.
Up to 3 points may be earned for efficient lighting under EA8 (Energy & Atmosphere).
NGBSNational Green Building Standard Based on the NAHB Model Green Home Building Guidelines and passed through ANSI. This standard can be applied to both new homes, remodeling projects, and additions.
/ICC-700 Under Ch. 7 — Energy Efficiency: up to 8 pts. for Energy StarLabeling system sponsored by the Environmental Protection Agency and the US Department of Energy for labeling the most energy-efficient products on the market; applies to a wide range of products, from computers and office equipment to refrigerators and air conditioners. Lighting package (704.2), up to 4 pts. for home energy "dashboard" (703.4.9, 705.1)
Learn more in the Green Building Encyclopedia
Further Resources
Image Credits:
- Daniel Morrison
Fri, 01/22/2010 - 14:23
the right tools for the right job
by Elemental LED staff
And of course having individual control of the various light sources helps, as well as appropriate technologies for various applications. LED lighting, for example, works very well as close application and task lighting.
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Subscribe to Green Miscellanea:
Comments
