Helpful? 2
Regional Variations on the ‘Pretty Good House’
Suggested specifications for Northwest Ontario, New Mexico, Sacramento, Florida, and North Carolina
Posted on Feb 20 2012 by GBA Team
The building-science-and-beer group that meets every month in Portland, Maine, recently launched a discussion of suggested specifications for a “pretty good house” — a house that seeks to balance construction cost and energy performance without being constrained by the dictates of existing green building programs or rating systems. Michael Maines's blog on that topic has generated dozens of comments, and GBAGreenBuildingAdvisor.com has received several e-mails from readers with suggestions for regional variations on the “pretty good house” concept.
So, without further ado, we present the Pretty Good Ontario House, the Pretty Good New Mexico House, the Pretty Good Sacramento House, the Pretty Good Florida House, and the Pretty Good North Carolina House.
Lucas Durand: Northwest Ontario
Since I was not particularly interested in any type of "official" certification for my new house in northwest Ontario, I began to pick and choose criteria that seemed reasonable from both a cost and performance standpoint.
Resiliency was a priority, with most of the attention on making the house livable in the event of extended power outages and during times of drought.
Simplicity of design. I found it best to keep everything as simple as possible. In terms of envelope design, simplicity had a lot to do with keeping everything buildable but also with minimizing complex geometry. In terms of resiliency, simplicity meant covering the basics by making decisions about what was needed and then not worrying about devising systems that would maintain what was wanted.
A vented attic was selected for cost, ease of construction and also for durability reasons. The underlying flat ceiling also offers more buildability and better performance than a more dramatic cathedral ceiling.
Wall trusses with airtight sheathingMaterial, usually plywood or oriented strand board (OSB), but sometimes wooden boards, installed on the exterior of wall studs, rafters, or roof trusses; siding or roofing installed on the sheathing—sometimes over strapping to create a rainscreen. . The walls are a type of stick-framed truss wall with airtight sheathing. As with the vented attic, this wall system was selected for its buildability but also because of my desire to minimize the use of rigid foam insulation.
5/10/20/40/60 insulation. For insulation, I followed the 5/10/20/40/60 guideline, but found it easy to add a little extra here and there (ie: sub-slab, sub-footing). It is my thinking that it is more important to focus on the quality of the insulation plan rather than the quantity. A complete thermal break around the entire envelope should be a priority; footings and slab should be fully insulated.
0.6 ach50. Air-sealing details should aim for the tightest possible construction but should be relatively easy to accomplish. Committing ahead of time to a service cavity enabled the use of certain air-sealing details that make Thorsten Chlupp's "0.6ACH50 made easy" achievable.
"Outie" windows may not offer the maximum performance advantage but are much easier to install and detail. Because of the climate I live in, locating the windows on the "outie" plane increases the risk for condensation in winter, so I bought the best triple-glazed windows I could afford.
A rainwater collection system. Regionally, Northwest Ontario has been drying out significantly in recent years. Given that I depend on a well for water, a cistern and rainwater collection system seem like more than just a good idea.
A wood stove. The grid can be unreliable during stormy weather. If the grid is knocked out when the outdoor temperature is -20C and there is no source of heat that does not rely on electricity, it becomes possible that the occupants of a house may have to abandon ship. Firewood is plentiful on the property, and an airtight wood stove makes good horse sense.
A solar thermal system. For renewable energy, I went with solar thermal for domestic hot water heating, and I plan to incorporate a small amount of PVPhotovoltaics. Generation of electricity directly from sunlight. A photovoltaic (PV) cell has no moving parts; electrons are energized by sunlight and result in current flow. as budget permits. Solar thermal is a relatively inexpensive way to get into renewable energy systems and, if combined with a small PV system and DC pumping, can increase household resiliency by providing hot running water in the event of grid outages. I avoided the idea of an elaborate PV system for reasons of cost but also for reasons of complexity.
My "pretty good house" is still under construction, but I am confident that it will meet my expectations. Once complete I am looking forward to monitoring its performance year after year. Please feel free to follow along with my progress at my blog.
Armando Cobo: New Mexico
I’ll start a list for Southern design criteria:
  • Passive solar design should be the first priority
  • Include large overhangs and porches
  • Insulation levels can be lower that for cold-climate houses
  • Triple glazingWhen referring to windows or doors, the transparent or translucent layer that transmits light. High-performance glazing may include multiple layers of glass or plastic, low-e coatings, and low-conductivity gas fill. is not needed
  • Install reflective roofs
  • Select light-colored materials
Mike Keesee: Sacramento, California
At SMUD (the Sacramento Municipal Utility District), we're big fans of pretty good house. We call our version of the pretty good house the “SolarSmart Home.” SolarSmart Homes included following measures:
  • R-38 attic insulation
  • Attic radiant barrier
  • R-13 wall insulation plus R-4 rigid foam
  • Energy StarLabeling system sponsored by the Environmental Protection Agency and the US Department of Energy for labeling the most energy-efficient products on the market; applies to a wide range of products, from computers and office equipment to refrigerators and air conditioners. windows
  • Minimum furnace efficiency: 90 AFUEAnnual Fuel Utilization Efficiency. Widely-used measure of the fuel efficiency of a heating system that accounts for start-up, cool-down, and other operating losses that occur during real-life operation. AFUE is always lower than combustion efficiency. Furnaces sold in the United States must have a minimum AFUE of 78%. High ratings indicate more efficient equipment.
  • AC specs: minimum 14 SEER(SEER) The efficiency of central air conditioners is rated by the Seasonal Energy Efficiency Ratio. The higher the SEER rating of a unit, the more energy efficient it is. The SEER rating is Btu of cooling output during a typical hot season divided by the total electric energy in watt-hours to run the unit. For residential air conditioners, the federal minimum is 13 SEER. For an Energy Star unit, 14 SEER. Manufacturers sell 18-20 SEER units, but they are expensive. and 12 EER
  • CFLCompact fluorescent lamp. Fluorescent lightbulb in which the tube is folded or twisted into a spiral to concentrate the light output. CFLs are typically three to four times as efficient as incandescent lightbulbs, and last eight to ten times as long. CFLs combine the efficiency of fluorescent light with the convenience of an Edison or screw-in base, and new types have been developed that better mimic the light quality of incandescents. Not all CFLs can be dimmed, and frequent on-off cycling can shorten their life. Concerns have been raised over the mercury content of CFLs, and though they have been deemed safe, proper recycling and disposal is encouraged. lighting
  • 1 kW to 2 kW PV system
Limited bill analysis shows that SolarSmart homeowners are using 50% less energy and saving about 54% on their electric bills vs. a control group. (We attribute the smaller savings to increased plug loads).
Although we're thrilled with the results, we knew we had to do better. To that end, we developed a HOme of the Future (HOF) R&D program. The goal of the R&D was to develop a package of energy efficiency measures combined with PV and solar thermal to reduce total annual source energy use by 80%:
  • R-50 ceiling insulation
  • R-30 wall insulation
  • Conditioned crawl space with R-10 wall insulation
  • Windows rated at U-0.30 and 0.26 SHGCSolar heat gain coefficient. The fraction of solar gain admitted through a window, expressed as a number between 0 and 1.
  • Minimum furnace efficiency 92 AFUE
  • AC specs: minimum 18 SEERSeasonal Energy Efficiency Ratio (SEER) is the total cooling output (in BTU) of an air conditioner or heat pump during its normal annual usage period divided by its total energy input (in Watt-hours) during the same period. The units of SEER are Btu/W·h. SEER measures how efficiently a residential central cooling system operates over an entire cooling season. The relationship between SEER and EER depends on location, because equipment performance varies with climate factors like air temperature and humidity. and 12 EER
  • HVAC(Heating, ventilation, and air conditioning). Collectively, the mechanical systems that heat, ventilate, and cool a building. system designed according to ACCA specs
  • Ducts located inside conditioned spaceInsulated, air-sealed part of a building that is actively heated and/or cooled for occupant comfort.
  • Mechanical ventilation system
  • Domestic hot water: solar thermal system plus tankless gas heater
  • HVAC system commissioningProcess of testing a home after a construction or renovation project to ensure that all of the home's systems are operating correctly and at maximum efficiency. includes verification of refrigerant charge and airflow over coil
  • Air leakage rate: 4 ach50
  • CFL lighting
  • 3.5 kW to 4 kW PV system
In brief, we're convinced that a “packaged” approach provides consistent results and a “pretty good house.”
Don't get me wrong. I like PassivhausA residential building construction standard requiring very low levels of air leakage, very high levels of insulation, and windows with a very low U-factor. Developed in the early 1990s by Bo Adamson and Wolfgang Feist, the standard is now promoted by the Passivhaus Institut in Darmstadt, Germany. To meet the standard, a home must have an infiltration rate no greater than 0.60 AC/H @ 50 pascals, a maximum annual heating energy use of 15 kWh per square meter (4,755 Btu per square foot), a maximum annual cooling energy use of 15 kWh per square meter (1.39 kWh per square foot), and maximum source energy use for all purposes of 120 kWh per square meter (11.1 kWh per square foot). The standard recommends, but does not require, a maximum design heating load of 10 W per square meter and windows with a maximum U-factor of 0.14. The Passivhaus standard was developed for buildings in central and northern Europe; efforts are underway to clarify the best techniques to achieve the standard for buildings in hot climates., LEEDLeadership in Energy and Environmental Design. LEED for Homes is the residential green building program from the United States Green Building Council (USGBC). While this program is primarily designed for and applicable to new home projects, major gut rehabs can qualify. , Greenbuilt, and the other green home programs. They push the envelope and set upper standards, but we need to recognize that these programs are not applicable for the huge majority of cases and will never achieve the market penetration we need if we want to achieve the energy savings we need to in new and existing homes. As laudable as these programs are, they are overly complicated, expensive, and in certain cases dogmatically rigid. Home buyers and owners, builders and contractors need easy to understand and implement and affordable solutions. Our experience at SMUD tell us that if we can deliver easy-to-understand, easy-to-implement affordable programs, our customers will respond.
Neil Porter: Florida
I live in Fort Myers, Florida. Our highs in January and February have often been in the 70s-80s. Basically there are only a couple days a year when it would be good to have solar gain through the windows. Otherwise it is never needed and definitely not desired.
No east or west windows. Good design for south Florida means no windows on the east and west walls because the low morning and afternoon sun heats up the home year-round and greatly increases the cost for air conditioning. North-facing windows are great because they only get early morning and late afternoon sun before and after June 21. With the sun at 85 degrees at noon on that date, it doesn’t take much of an overhang to shade south-facing windows.
Put the lanai on the north side of the house. Ideally the front would face south. In our area virtually no porches have been built on the fronts of homes for decades. Most homes have a screened enclosure (called a lanai here) in the back. This is because six months of the year we have a lot of mosquitoes. Usually a double sliding glass door from the dining room and often from the master bedroom and sometimes from a second bedroom lead to the lanai. Having these large glass surfaces face north reduces a lot of solar gain. Having the lanai face north also keeps it much cooler because the house and roofed portion keep it shaded. A lanai that faces west, south or east is much less comfortable nine months of the year. The lanai should also jut out from the back of the home with screens on three sides to benefit from cooling breezes.
Wide overhangs aren't good in hurricane territory. When I first started researching green building in Florida, wide roof overhangs were recommended. But when hurricane resistance entered the picture, as it must in all of Florida, overhangs shrank to one foot. The exception is the covered portion of our lanais. These are called “under truss” because they are integrated into the home’s roof. The trusses are supported by a poured concrete tie beam which rest on concrete pillars.
You don't need thick insulation or expensive windows. To understand this, northern people need to keep our climate in mind. For the most part we design for efficient air conditioning at least six months of the year. There are exceptions but generally our hottest temperatures are about 95 degrees. Keeping the interior air conditioned to 76-78 degrees means that there is only a 17-19 degree difference in the summer afternoons. As a result, thick insulation on walls and expensive insulated windows is not a good use of available funds. Tight-fitting windows with reduced air infiltration, on the other hand, is a good thing because of our high humidity which is generally 80-100% every night year-round. This high humidity at night coupled with 80-85 degrees still at midnight means that we can’t open windows at night during our long summers. For most people the home is kept tightly closed for six months once the temperatures get too hot.
Choose reflective roofing. A major part of our heat gainIncrease in the amount of heat in a space, including heat transferred from outside (in the form of solar radiation) and heat generated within by people, lights, mechanical systems, and other sources. See heat loss. is through the roof, so having a highly reflective and emissive white metal roof should be one of the top priorities. Whereas a heat-absorbing shingle roof lasts about 20 years at best in this climate, a metal roof will last 40-50 years. Shingles then usually go to the dump. Metal, on the other hand, can be easily recycled. Metal roofing is also much more resistant to hurricane-force winds. The downside is that metal is about twice as expensive.
Choose light-colored siding paint and plant vegetation. Since many homes here are built with uninsulated concrete blocks, using light-colored exterior paint or shading the walls with vegetation can help reduce energy costs.
Install a solar hot water system. Get a solar water heater in every existing and new home and accomplish a reduction in energy use for a small investment and short-term payoff.
Include an unvented conditioned attic. Insulating the underside of the roof sheathing with spray foam not only insulates an unvented attic keeping the humidity out but also greatly increases the uplift resistance to hurricane-force winds. Also, since air conditioner ducts are always installed in our attics and often the air handler, reducing the attic temperature in this way greatly reduces the heat transferred to the ducts.
Install a programmable thermostat. For people that are regularly away from the home for several hours a programmable thermostat with an unoccupied temperature of 85 degrees can greatly reduce energy costs.
Leigha Dickens: North Carolina
Here are the design principles I follow when advising customers who want to build a Pretty Darn Green home in my mountainous, mixed-humid climate:
Passive design first of all! Do use south-facing windows, thermal massHeavy, high-heat-capacity material that can absorb and store a significant amount of heat; used in passive solar heating to keep the house warm at night. , and super-insulation for passive solar heating. Yet don't cut down those trees, if you have them: the provide many dollars worth of summer cooling, and deciduous trees which lose their leaves in winter will still allow in a great deal of sunlight. Avoid east and west facing windows, as low-angle sun in summer can add a lot of extra heat when it’s not wanted. Also, resist the urge to “oversize” your passive solar by building what amounts to an attached greenhouse on the south side of your home: work with a design professional to get the glass-to-thermal-mass ration right. I have seen so many homeowners regret that their large south-facing space becomes virtually unlivable in the swing seasons because they put in too much south-facing glass. A little goes a long way in this particular climate, especially as winters can have remarkably warm spells intermixed with the cold.
Start with R 10-15-30-50 for superinsulation. Blown-in blankets or cellulose, rather than batts which tend to be installed poorly, are a well-performing and cost-effective choice for walls, while cellulose or spray foam insulation are good for the ceiling or roof deck.
Incorporate livable outdoor space like covered or screened porches, patios, and decks. There's a good chunk of the year when it's darn nice outside, and having outdoor space can make smaller indoor square footages feel more comfortable.
Install a high-efficiency heat pumpHeating and cooling system in which specialized refrigerant fluid in a sealed system is alternately evaporated and condensed, changing its state from liquid to vapor by altering its pressure; this phase change allows heat to be transferred into or out of the house. See air-source heat pump and ground-source heat pump. and AC and have a thorough mechanical design and commissioning to avoid oversizing. Keep the ductwork and air handler inside of the building envelopeExterior components of a house that provide protection from colder (and warmer) outdoor temperatures and precipitation; includes the house foundation, framed exterior walls, roof or ceiling, and insulation, and air sealing materials., or go ductless with mini-splits. The subject of air conditioning is as hot button among green types, and I’ll admit to being captivated by the romance of natural ventilation and the energy savings of AC-free living. However, in our occasionally-very-cold but mostly-mild winters, you can't beat a heat pump for energy efficient heating, which means the ductwork and machinery is essentially already in place for air-conditioning, as well. And a large part of what an AC does (when not oversized) is dehumidify. Humidity can make even an otherwise pleasant temperature feel very uncomfortable, and we have a lot of it. It can also create an ideal environment for indoor mold and mildew growth, impacting occupant health and reducing the durability of interior finishes.
Build a home with solid moisture-management techniques. Although that is important in any climate, it rains a lot here and is very often quite humid, so there is less margin for error. Sloping lots, deep overhangs, gutters, a behind-the-siding drainage plan, correct wall and roof flashing, capillaryForces that lift water or pull it through porous materials, such as concrete. The tendency of a material to wick water due to the surface tension of the water molecules. breaks. Building assembly components must be built to dry in both directions: so vapor barriers on any side of the enclosure should be avoided.
Solar electric, wind, solar thermal, geothermal are the icing on the cake and should be considered only after you’ve built a passive, super-insulated, reasonably air-tight home and durable home with a modest footprint.
Tags: , ,
Image Credits:
  1. Lucas Durand
1.
Tue, 02/21/2012 - 13:45
Prescriptive vs. Performance
by michael maines
Helpful? 0
Mike Keesee,
How did SMUD decide to go with a prescriptive path instead of a performance path? How did you determine what the prescriptive numbers would be?
2.
Tue, 02/21/2012 - 14:20
Good to see the regional
by Richard Patterman
Helpful? 0
Good to see the regional differences. In a country this big, with our vast differences in climate,
it is good to admit that "one size does not fit all".
3.
Tue, 02/21/2012 - 19:17
Michael Maines Question and the Pretty Good Retrofit
by mike keesee
Helpful? 0
Michael,
SMUD adopted a prescriptive approach for its Solar Smart Homes program because it was easy for produciton builders to understand, easy to administer, and produced results. I'mnot sure what you're asking in your question about how we determined the prescriptive numbers. The original Solar Smart Home EE package was based on BEopt simulation that were field tested in two subdivsion scale demonstration projects.
That being saide, we recently announced an updated version of the SolarSmart Homes program that utiliizes a performance approach based on how much better the home performs relative to its Title-24 energy requirements, providing an $1150 incentive for homes that exceed the Title-24 by more than 20% and maxin out at $2250 for homes that exceed Title-24 by more than 40%. the change was made in response to updates to Title-24 which saw a 15% improvement in the code and to align our program with the investor owned utility California Advanced HOme program. However, in practice we recommend a 40% packjage of EE measures.tou our builder customers.
I also failed to mention, or just ran out of room, that I think the EE package approach will also result in a pretty good retrofit, too. I just completed 6 deep energy retrofit R&D projects and find that for our climate and for homes built before the introduciton of Title-24 (1978) you could get about 60% energy savings with an EEM package that included:
• Air Sealing the home to a minimum 7.5 Air Changes per Hour (@ 50 pa of pressure)
• Energy Star Windows (.30 U-Factor and Solar Heat Gain Coefficient)
• “Right sized” SEER 14 air conditioner, 0.95 AFUE furnace or 9.5 HSPF Heat Pump with tight (less than 6% leakage), R-8 insulated ducts
• .65 EF Gas Storage Water heater or 2.0 COP Heat Pump Water Heater
• Energy Star Hard Wired CFL Fixtures
This EE package bascially brings the home up to current new home, Title-24 standards. It also asssumes that the occupants don't go overboard on miscellaneous plug loads, an increasingly difficult issue to address. I also argue that a retrofit package approach that emphasizes "right sized" HVAC will result in significant permanent peak savings which is of particular value to utilities - something tht doesn't get mentioned enough.
Just like in new construction, a retrofit package is easy for everyone to understand - contractors and homeowners, and if implemented at the time of re-sale, a under appreciated, neglected market, with an energy efficient mortgage, would be easy for real estate agents and mortgage under writers to understand, too.
The point I'm trying to make, a view I think the pretty good guys are also trying to make, is that we spend a lot of time fussing and fretting about estimated energy savings and try and justify the exercise with energy simulation modeling, especially in the utilty world. Those of us who've been doing this for a while know what works and what doesn't. And if we're going to achieve the energy savings numbers we need to to address the host of issues confronting our society, we need to get on with it. Energy simulation has its place in framing what the EE package should look like, but I don't think we need to do an overly complicated analysis to determine how to improve the performance of a new or existing home. A recent report done for the DOE by NREL, "Energy Savings Measure Packages: Existing Homes," is an excellent start on getting pretty good home retrofit packages for existing homes across the country.
4.
Wed, 02/22/2012 - 07:54
Response to Mike Keesee
Helpful? 0
Mike,
Your final paragraph is an important statement. Well put!
Here's a link to the document that Mike mentioned: Energy Savings Measure Packages: Existing Homes.
5.
Thu, 02/23/2012 - 12:42
Edited Thu, 02/23/2012 - 12:43.
our current new pretty good house
by Mark Dickerson
Helpful? 0
I am in the later stages of a house we designed which consists of ICF construction, 2.5" X 2.5" EPS wall Logix ICFs plus 6.25 inches concrete, Triple pane double hung windows, 85% of the windows to the south, 20 inches blown in cellulose (R60-70) in the ceiling, R26 under the slab, R26 down to 4 feet underground, air/vapor barrier above the ceiling sheetrock, and an internal 2X4 wall (inside the ICFs) to maintain the integrity of the ICF insulation. Hopefully the ICFs will perform as advertised, and hopefully we should get a very low air infiltration (unk exactly what numbers yet). There will be an EHRV system to exchange the air, and no chimney or fireplace or gas inside. 2 flash electric water heaters, one for the floor radiant heat (in 4 inches of concrete) and one for domestic water.
I thought about getting the Passive consultants out of Boston to certify this design and house, but with a quote of 18,000$ to do that, I used that money for a metal roof.
steve d
Ashburnham, Mass.
6.
Fri, 02/24/2012 - 23:39
In praise of energy modeling
by Dan Kolbert
Helpful? 0
Mike - I am a bigger fan of energy modeling than you are. I'm not a huge proponent of PH, but I think PHPP is terrific software. From my brief experience with it, it helped make some decisions on a job.
But as to your larger point, yes, I think you're right - there's plenty of knowledge out there, and Martin's efforts to bring out the regional expertise is right on. But I also think we're learning new things all the time - and the beauty of the digital age is we can share it.
I think our group is going to keep plugging away on our local version - there's a lot of enthusiasm for it. And like you, much discussion here as well about the Pretty Good Retrofit, although our old housing stock, with stone and brick foundations (and lots of clay) makes it trickier.
7.
Fri, 02/24/2012 - 23:42
How'd you decide?
by Dan Kolbert
Helpful? 0
Steve D - how did you make your decisions? There are some things I would have recommended against (like double hung/triple glazed, and ICF's in general), but there are plenty of ways to skin a cat - what methods did you use to make cost/benefit analyses?
8.
Mon, 02/27/2012 - 12:44
Cold Weather Climate States - Midwest
by Brett Little
Helpful? 0
There is one issue I can share that we have identified in our area and hopefully more to come. The problem we have here is that fibrous insulation cannot be compared to foam based insulation in regards to R Value in our area. Due to convection that is not accounted for in these measures, foam is going to be much more effective.
9.
Mon, 02/27/2012 - 15:19
Response to Brett Little
by Lucas Durand - 7A
Helpful? 0
Brett,
I think fibrous insulation will work just fine in your climate.
The key is to ensure that you have at least one good air barrier.
Ideally in a cold climate, the air barrier should be on the warm in winter side of the envelope while the exterior can have a "pretty good" windbreaker to minimize wind-washing - properly detailed housewrap should be fine for a windbreaker.
10.
Thu, 03/22/2012 - 09:54
Texas PGH?
by Kelly Wunsch
Helpful? 0
Has anyone seen a post with suggestions for a Texas version of the PGH? This is a great thread, but I get disappointed that in this thread (as well as most others in this forum) there rarely seems to be much in the way of information specific to the hot and sometimes-humid climate we have here in central Texas (Austin). Ours is mainly a cooling climate, though our delta-T between indoor and outdoor temps rarely exceeds 30 degrees or so--in winter OR summer. While your insulation suggestions sound very prudent in extreme climates, I wonder if the money used in superinsulating a house is better spent in other areas in our climate. Our local green-building program (run by Austin Energy) thinks so, but I was curious as to you guys' thoughts here.
11.
Thu, 03/22/2012 - 10:14
Response to Kelly Wunsch
Helpful? 0
Kelly,
GBA welcomes any Texas builders to submit their suggestions here. In the meantime, here are some of my recommendations for hot-climate house design: Hot-Climate Design.
Become a GBA PRO!
