Honda Builds an Experimental House
The net-zero energy house at the University of California Davis incorporates many energy-efficient features and comes with its own battery-powered car
Image 1 of 4
Honda's experimental two-bedroom home was designed to test a variety of energy-saving features. Honda has announced that it will share the specs and architectural drawings for the 1,944-square-foot house with anyone who wants them.
Image Credit: Honda
Image Credit: Honda
Contemporary design: The interior of the Honda Smart Home is bright and clean, but the focus will be on its electrical management system and energy-saving features rather than the architecture.
Image Credit: Honda
Solar electricity for both car and house. Honda says the 9.5 kW photovoltaic system should be enough to power the house and keep a Honda Fit EV charged.
Image Credit: Honda
Energy management is key. A sophisticated energy management system shows where power is coming from and how it's being used.
Image Credit: Honda
Honda’s long list of consumer products already includes cars, outboard motors, portable generators, motorcycles, and lawnmowers — so why not houses?
The company in March opened the doors to the first Honda Smart Home, a high-tech, net-zero energy house on the West Village campus of the University of California, Davis. It comes with many features that are becoming standard in high-performance houses — a ground-source heat pump, a roof-mounted photovoltaic array for electricity, a gray water system for watering plants, and triple-paned windows. There’s also a Fit electric car in the garage.
The 1,944-square-foot two-bedroom house is designed to produce all of the power it needs, including enough juice to keep the car charged.
Honda isn’t planning on building replicas of the house elsewhere, or licensing others to do so, says Marcos Frommer, Honda’s corporate affairs and communications manager. It’s intended as a demonstration project only.
“It allows us to engage with the public and the technical community about a zero-carbon future while allowing us to research potential future solutions,” Frommer said in an email. “Honda will be making available for free our architectural drawings and complete specifications so that others may conduct similar research, or build this house for their own personal use.”
Honda didn’t say how much the house cost to design and build. Construction started in April 2013 and the house opened on March 26.
Carbon reduction is a key part of the design
Together, homes and light-duty vehicles now contribute roughly 44% of total U.S. greenhouse gas emissions, Honda said, and developing technologies that help reduce that number is one of the project’s main objectives.
In a detailed description of the house, Honda said it expected the house would generate a surplus of 2.6 megawatt-hours of electricity per year for a net offset of 6 1/2 tons of carbon dioxide. When the electric car is added to the equation, Honda said the total avoided emissions should rise to nearly 12 tons of C02.
Honda looked for carbon savings wherever it could find them, including the concrete used in the post-tensioned slab. Making cement from limestone by heating it up in giant kilns is responsible for about 5% of global C02 emissions, Honda said. So half the cement in this concrete was replaced with a concrete extender called pozzolan.
Energy management system can talk to the grid
The company developed a home energy management system that monitors and controls the generation and use of electricity. The electrical system, which includes a 10 kilowatt-hour battery in the garage, is designed to minimize the home’s impact on the grid by responding to changing conditions. If the grid gets overloaded, for example, the system can reduce consumption in the house and route power from its PV array to the grid.
The Honda Fit has been modified to accept DC current directly from the 9.5-kW solar array, which the company said is more efficient than converting the direct current to alternating current as would normally be the case. When making power at full capacity, the panels can charge the car’s batteries in two hours.
Other features of the home include:
  • Double stud wall construction. Above-grade exterior walls are made from two 2×4 stud walls on 24-in. centers designed to eliminate thermal bridging except at the fire blocking. The 9 1/2-in. wall cavities are insulated with cellulose (R-31).
  • Triple-glazed windows. The argon-filled casements are manufactured by Alpen.
  • A truss roof with a vented roof deck. The roof is insulated to R-60 with cellulose.
  • Insulated slab. Rigid foam under the concrete slab has an R-value of 10.
  • Airtightness. The house tested at 2.0 air changes per hour at a pressure difference of 50 pascals.
  • Lumber. All lumber used in construction came from forests certified by the Forest Stewardship Council.
  • Water management. There are dual-flush toilets, and low-flow faucets at sinks and showers in the 2 1/2 baths. Outside, xeriscaping is irrigated exclusively with filtered gray water.
  • Light system. LED lighting developed with researchers at the California Lighting Technology Center mimics the natural shift in daylight from morning until night. The company calls it “circadian color control logic.”
Honda said it would seek certification from LEED for Homes, the National Green Building Standard, and Energy Star.
Someone from the UC-Davis community will be living in the house; the name of the future occupant wasn’t announced.
