green-building-newsheader image
0 Helpful?
Passivhaus Apartment Complex Would be a Giant
Scheduled to begin construction in October, this 276-unit multifamily project in Kansas City will seek certification from PHIUS
Posted on Sep 16 2015 by Scott Gibson
When ready for occupancy in early 2017, the 276-unit riverfront apartment complex would be the largest Passivhaus-certified building in the country and, according to its developer, help Passivhaus construction shed its "boutique" status and begin to interest big institutional investors.
The "Second and Delaware" project, named for its location in a historic warehouse district just north of downtown Kansas City, will include a range of apartment sizes, from 550-square-foot studios to 1,300-square-foot, two-bedroom models. It also will feature rooftop gardens and an underground 500-vehicle parking garage.
The $60 million project is the work of the Arnold Development Group, which hopes to show that projects that are good for the environment and for the people who live in them also can have an attractive bottom line. It would dwarf what is now the largest Passivhaus project in North America, the 57-unit Orchards at Orenco project in Hillsboro, Oregon.
Company founder and CEO Jonathan Arnold said by telephone that the Kansas City project is an effort to construct a building that will last hundreds of years, "amortizing" the carbon footprintAmount of carbon dioxide and other greenhouse gases that a person, community, industry, or other entity contributes to the atmosphere through energy use, transportation, and other means. of construction over a very long time frame. He hopes it will convince institutional investors, which now buy most big multifamily projects in the country, that structures built to the Passivhaus standard are better long-term investments than less expensive buildings with lower initial costs but lower life expectancies.
Arnold Development will seek certification through the Passive HouseA residential building construction standard requiring very low levels of air leakage, very high levels of insulation, and windows with a very low U-factor. Developed in the early 1990s by Bo Adamson and Wolfgang Feist, the standard is now promoted by the Passivhaus Institut in Darmstadt, Germany. To meet the standard, a home must have an infiltration rate no greater than 0.60 AC/H @ 50 pascals, a maximum annual heating energy use of 15 kWh per square meter (4,755 Btu per square foot), a maximum annual cooling energy use of 15 kWh per square meter (1.39 kWh per square foot), and maximum source energy use for all purposes of 120 kWh per square meter (11.1 kWh per square foot). The standard recommends, but does not require, a maximum design heating load of 10 W per square meter and windows with a maximum U-factor of 0.14. The Passivhaus standard was developed for buildings in central and northern Europe; efforts are underway to clarify the best techniques to achieve the standard for buildings in hot climates. Institute U.S. (PHIUS).
Insulated concrete walls will be 16 inches thick
The apartments will be built around a central courtyard; the south-facing walls will be four stories tall and those on the north side stepped up to as much as six stories high. Unlike a "Texas doughnut" multifamily design that places outward-looking apartments around a core parking area, this project will enhance a sense of community with open space where residents can gather.
The exterior walls will be what Arnold called a "concrete sandwich wall" consisting of a 6-inch-thick wythe on the outside, a 4-inch-thick wythe on the inside, and a 6-inch layer of expanded polystyrene foam insulation in the middle. Inner and outer layers of concrete will be connected with fiberglass ties placed every 18 inches. The ties, Arnold said, have very high tensile strength and a low potential for thermal bridgingHeat flow that occurs across more conductive components in an otherwise well-insulated material, resulting in disproportionately significant heat loss. For example, steel studs in an insulated wall dramatically reduce the overall energy performance of the wall, because of thermal bridging through the steel. .
Wall insulation will run continuously up to the parapet level to meet the tapered rigid insulation in the roof, which will vary in thickness from 12 inches to 15 inches. Original plans called for polyisoPolyisocyanurate foam is usually sold with aluminum foil facings. With an R-value of 6 to 6.5 per inch, it is the best insulator and most expensive of the three types of rigid foam. Foil-faced polyisocyanurate is almost impermeable to water vapor; a 1-in.-thick foil-faced board has a permeance of 0.05 perm. While polyisocyanurate was formerly manufactured using HCFCs as blowing agents, U.S. manufacturers have now switched to pentane. Pentane does not damage the earth’s ozone layer, although it may contribute to smog. insulation in the roof, but Arnold said that could be changed in favor of extruded polystyrene.
The buildings will be constructed with an innovative concrete-forming technique in which walls, floor slabs and columns are poured as a monolithic unit. The aluminum forms made by Western Forms are engineered for this specific job and can be assembled two to five times faster than conventional concrete forms, Arnold said, helping to lower construction costs.
With the monolithic concrete pours and continuous insulation, he said, the building achieves what Passivhaus certification requires — a continuous, non-thermal bridging insulation layer and, thanks to the concrete, very low levels of air leakage.
A "structural grid system" designed for the project by its structural engineers includes concrete columns on roughly 30-foot centers, allowing interior walls that are not load-bearing. On the first floor, Arnold said, this design would permit a change in use from residential to something else — an urgent care center, for example — at some point in the future without changing the structure of the building.
"Some of this started with a trip to Rome and looking at the Parthenon and saying, 'This building has been around for 2,000 years, practically,'" Arnold said. "'This is really incredible. Imagine if we could make a flexible structure that, if maintained, could last a very long time."
Renewable energy in the mix
Staengl Engineering estimates monthly utility bills for tenants will range from $17.24 for someone living in a 550-square-foot studio to a high of $40.76 for a 1,300-square-foot apartment. Energy consumption would be 235 kWh and 555 kWh respectively.
Heating and cooling will be provided by a variable refrigerant flow (VRF) system with an energy-recovery ventilator (ERV(ERV). The part of a balanced ventilation system that captures water vapor and heat from one airstream to condition another. In cold climates, water vapor captured from the outgoing airstream by ERVs can humidify incoming air. In hot-humid climates, ERVs can help maintain (but not reduce) the interior relative humidity as outside air is conditioned by the ERV.) located at each floor level. Domestic hot water will be produced by a Capstone Microturbine running on natural gas.
Triple-pane windows will have a whole-window U-factorMeasure of the heat conducted through a given product or material—the number of British thermal units (Btus) of heat that move through a square foot of the material in one hour for every 1 degree Fahrenheit difference in temperature across the material (Btu/ft2°F hr). U-factor is the inverse of R-value. of 0.13 and a solar heat gain coefficient(SHGC) The fraction of solar gain admitted through a window, expressed as a number between 0 and 1. (SHGCSolar heat gain coefficient. The fraction of solar gain admitted through a window, expressed as a number between 0 and 1.) of 0.4, according to Staengl's report.
The project will have a photovoltaic(PV) Generation of electricity directly from sunlight. A photovoltaic cell has no moving parts; electrons are energized by sunlight and result in current flow. array on the top of each of the two C-shaped buildings, for a total rated capacity of 150 kW.
Galen Staengl said by telephone that while the R-valueMeasure of resistance to heat flow; the higher the R-value, the lower the heat loss. The inverse of U-factor. of the exterior wall (R-23) seems low for a Passivhaus structure, the building has a much higher ratio of interior space to wall than a single-family building would have.
"The more interesting thing is that in multifamily buildings, with a good surface-to-volume ratio, the insulation levels that are required are much lower than for a single-family residence purely because of that improved surface-to-volume ratio," he said.
"Passivhaus requirements are envelope requirements," he continued. "There's an envelope load requirement but it's a per-square-foot number, and so in a big multifamily building where you have a very advantageous surface-to-volume ratio, there's a lot less heat loss in general. Because you're starting out with that advantage, the additional insulation required to get to a Passivhaus wall is much lower, and in some cases is actually approaching code on the wall."
When building means more more than making a profit
Arnold's work with a United Nations sustainable development project and the Rio +20 conference convinced him that some sustainable housing solutions were just too big for most non-profits to handle. They required the financial muscle of a larger for-profit corporation, but rules governing conventional corporations were too restrictive.
Arnold Development is a registered B Corporation, a designation which allows corporate officers to pursue projects even when they don't necessarily maximize shareholder value. A B Corporation is free to look for what Arnold called a "triple bottom line" — results that benefit people, planet, and profit.
Part of that formula will be the inclusion of affordable housing in the Kansas City mix; 20% of the apartments will be earmarked for people who earn 50% of the average median income in the area. And those apartments will be mixed in with those selling at market rates. "The idea is you nip gentrification in the bud," Arnold said.
According an article in The Kansas City Star, Arnold hopes to introduce a financing plan that allows residents to build equity in the property by purchasing shares in a real estate investment trust (REIT) rather than simply paying rent.
"The REIT model has the potential to revolutionize the rental housing market by effectively turning renters into owners in the underlying real estate assets,” he told the newspaper. “Within a generation, entire neighborhoods made up of sustainable, long-lasting, multifamily housing could be ‘owner-occupied’ and debt-free.”
Big enough to make a difference in the industry
Second and Delaware, which Arnold Development plans to own as well as develop, is big enough to show large institutional investors a type of construction that is not only feasible but profitable. Smaller projects, those with fewer than 250 apartments, are outside the sweet spot for large investors, he said, so a meaningful shift in the housing industry will require projects that institutional investors are willing to underwrite.
"What we wanted to do was move Passivhaus out of the small boutique kind of scale," he said. "Institutional investors — pension funds, and REITS, life insurance companies — are the ones that are buying the majority of multifamilies in the U.S., and they're not going to buy a 100-unit project. It's not big enough for them. Two hundred and fifty units is the low end of the sweet spot for maximizing onsite labor. If you have less than 250 units, the institutional investors have found the economies of scale aren't there.
"If we really want to make an impact on what's being built," Arnold continued, "we need to build product at a scale that's going to be attractive to their investment criteria. This is the first truly institutional scale, institutional investor scale, project."
There are also good financial reasons for embracing Passivhaus construction, he said. Although higher in cost initially, they will have lower operating costs, much lower long-term maintenance costs and will prove to be more profitable than projects that are "myopically focused on first costs."
Tags: , , ,
Image Credits:
  1. Arnold Development Group
Become a GBA PRO!
