Helpful? 0
U.K. Victorian Finds Its Way to Passivhaus Performance
The makeover of a 19th-century row house in West London meets the stringent standard and local historic preservation requirements
Posted on Apr 27 2011 by Richard Defendorf
UPDATED with a corrected R value for the shell, plus additional details about the project’s renewable-energy systems and its overall cost.
Builders and remodelers who aim to transform U.K.’s housing stock from leaky and creaky to highly energy efficient face daunting challenges. One of the premiere examples of a successful transformation is an 1860s Victorian row house that was recently retrofitted to perform to the Passivhaus standard.
As the interior walls and ceilings of the four-bedroom home were stripped to the timbers, the 2,526-sq.-ft. building disclosed a number of unexpected features, some the product of age and a few that were just plain disturbing. In a blog post about the project, team leader Green Tomato Energy, a London-based specialist in energy-efficient building, noted the following discoveries once the framing was exposed: “woodworm in almost every piece of timber in the house; structural columns sitting on midair, supported by precisely nothing; brickwork that looks more like pebble-dash than a wall; 6-cm. gaps between first and second brick layers on external walls; bowed walls throughout (which are particularly trying when applying insulation).”
Honoring architectural heritage
Those on Green Tomato’s design-and-construction team who were from the U.K. were probably more than nominally familiar with the challenges inherent in deep energy retrofits of this sort. Beyond addressing those issues, though, the team also had to comply with historic-conservation rules governing the building’s appearance and materials, a process that typically requires considerable cost, patience, and caution. (A GBA post about a deep energy retrofit of a 19th-century Victorian in northeast London notes that the project took more than two years from beginning to end.)
The good news is that Green Tomato, which is involved in other Passivhaus projects in the London area, persevered. It took about a year to bring the renovation far enough along for Passivhaus certification, which the house earned last month, along with an airtightness reading of 0.4905 air changes per hour at 50 Pascal pressure difference.
Teaching an old building new tricks
Because much of the original timber was compromised in some way, the team used a combination of steel (more than 5 tons of it), wood, and manufactured studs and joists to rebuild and steady the skeleton. A 130-mm. layer of Kingspan Kooltherm rigid closed-cell foam was installed outside the OSB sheathing on the roof and exterior walls (see image number 5), and a 50-mm. layer of rigid foam was installed on the inside of the roof and wall framing. Aluminum tape was used to seal gaps. The Green Tomato project blog notes that the insulation package delivers thermal resistance of U-0.1 (R-56.78).
The project’s triple-glazed windows, which had to conform to the sizes and styling of the originals, were custom built by Ryder Strategies Europe using newly developed glazing from Pilkington Glass. That process took a few months longer than originally planned, although the windows met every design and performance requirement.
The house is equipped with a small photovoltaic system (1.17 kW) whose array is angled unobtrusively on an A-frame on the flat rooftop, and two solar thermal flat-plate panels (5.57 kW) embedded in the slate-shingle roof. The project’s only other renewable energy system is a labyrinthine heat exchange the builder devised and then installed under the kitchen floor – it is about 3 ft. underground, covers about 300 sq. ft., and is sealed with an antibacterial film – to “prep” the incoming air to about 55 degrees F before it reaches the building’s heat recovery ventilator, a Genvex Combi. The total cost of the renovation came to about $414,300.
Tags: , , ,
Image Credits:
  1. Green Tomato Energy
Become a GBA PRO!
