Creating an Urban Oasis: A Green Live-Work Space Blooms on a Gritty City Lot
Recyled shipping containers, energy-scrimping details and a sophisticated design sense create a handsome urban compound in a transitional neighborhood.
Image 1 of 12
Not long after his design-build firm outgrew the first shipping container that housed its office, Stephen Shoup added a second. Here, Shoup guides the second container through the trees and over the fence, to be placed on four concrete piers, where it would rest perpendicular to the first container.
One of the great tests of green building will be how well it thrives in inner cities and other inhospitable environments. To put his green beliefs to the test, contractor Stephen Shoup bought a woodshop in a marginal neighborhood of Oakland, Calif., and converted it into a work-live space that housed both him and his design-build business, buildingLab. It was a tight fit; his living room frequently doubled as a lounge for his crews — but it worked while he was single.
Then Stephen fell in love with Taya Rhodes, a landscape architect, and shortly they were in full nesting mode, with a baby on the way. Clearly, it was time to get the work out of work-live space. Ultimately, Shoup decided to house his business in a pair of shipping containers, which contractors often use as satellite offices on job sites.
How Stephen and Taya turned the containers into an attractive, cost-effective and ultra-green home office — and transformed a gritty lot into an elegant courtyard — should cheer green advocates and city dwellers alike.
Roads not taken
As it turns out, shipping containers were the last option Stephen considered. The original woodshop was basically a big box, so he first thought about adding another smaller box atop it. That would have triggered a design review, however, because the original building had been built right on the northern property line, with no setback. Thus, to satisfy current zoning requirements, a second-story addition would have had to be set back 20 ft. from the building’s northern face. Consequently, the addition that resulted would have been too small to be feasible.
Once building up was out of the question, Shoup thought about adding a bump-out along the eastern or western ends of the building. Either bump-out was appealing because it would create an L-shaped structure that could eventually become a courtyard. But a bump-out to the east would have blocked the afternoon sun of his nearest neighbor. Whereas a bump-out to the west would have obstructed access to Shoup’s driveway, which ran along that side, and blocked views of an adjacent park.
A self-contained courtyard
At that point, the best option became obvious. Setting a shipping container along the southern side of the property (parallel to the main house) and then placing a second one at a right angle to the first would create an L-shaped office. The driveway and views to the west would be unaffected and three sides of a courtyard would be in place. The last piece of the puzzle was landscaping. By planting a long bank of bamboo along the east, Stephen and Taya could screen views of their neighbors’ house without blocking its sun.
The layout had everything going for it. It created a sense of privacy and safety without feeling claustrophobic. Because of a downturn in the global economy, shipping containers were cheap and readily available. (A 2008 New York Times piece estimated that 700,000 containers sat idle in the U.S.) Best of all for the expecting couple, the solution was fast. “Containers are like big box beams,” Shoup explained. “They can be placed on concrete piers rather than on a tee foundation, which costs more, takes longer to build and guzzles resources. So buildingLab's office really is green from the ground up.”
Urban green galore
Even for a green aficionado, there was an amazing amount of recycled materials used in turning the containers into an office. Like many general contractors, Shoup had a stash of building materials he’d salvaged from jobs over the years. But his stash of salvage wasn’t just a matter of saving money and recycling. The salvaged redwood and fir boards were re-used as siding and paneling for aesthetic reasons: to soften the hard lines of the containers and add warmth and natural beauty to what would have otherwise been vast expanses of metal.
And, Shoup freely admits, he wanted to experiment with all that salvage because it’s his place. He could try things that he might not want to risk if it were a client job and somebody else’s money. There’s no one right way to insulate a corrugated container, for example. In standard construction, most of the materials are flat, so framing, sheathing, insulation and finish surfaces are applied like so many layers of a cake. But how do you fit a pocket door into a wavy metal wall, for example? It was all a great adventure. Not unlike the head-scratching and Ah-ha! moments any homeowner experiences when he or she takes on a DIY task they’ve never done before. You figure things out.
The common sense of green
Building is, after all, mostly common sense:
(1) If you’ve got a small structure (each container was 8 ft. x 8 ft. x 16 ft.) and need to squeeze every usable inch out of a room’s interior...insulate the exterior.
(2) If you want to reduce lighting costs, maximize natural light by adding windows, skylights or light tubes.
(3) If you install solar panels to pre-heat water in the office’s radiant floor system, add a few more valves and pipes and pre-heat the water for the main house as well.
(4) If you like the look of a natural material or an irregular surface and don’t want to hide it—don’t. You’ll save money and delight your eye. Shoup left part of the container’s exterior wall and all of its corrugated ceiling exposed because he likes its look and thinks it “tells a story” about how the office is constructed.
buildingLab's green touches
Shoup’s home-office compound has an impressive number of green touches, starting with its recycled shipping containers. Other energy- and resource-saving details include:
- Sustainably grown cork flooring
- Radiant floor heating, with water preheated by hydronic roof panels
- Fluorescent lights throughout, natural light maximized
- Homasote (recycled newspaper) interior panels instead of drywall
- Framing lumber salvaged from deconstruction, not demolition
- Recycled redwood siding, fir paneling and windows
- Super-insulated shell, including R-20 rated floors
- Cement-board siding containing fly ash (recycled industrial waste)
- Drainage plane beneath siding to reduce heat and moisture build-up
- Reflective roofing to reduce cooling costs
- Improved permeability in the courtyard
Future present
Above all, the building choices you make should reflect who you are and how you want to live, now and in the future. As the office neared completion and their house filled up with baby gear, the future was certainly very much on Taya and Stephen’s minds. “How we live will have a great impact on our daughter because we seem to be on the cusp of huge changes, global changes,” they said. “Yes, building decisions are tangible choices, but they’re also moral ones. And by the time she’s old enough to understand the path we’ve chosen, we want her to be proud of us.”
If this case history inspires you to create a green live-work space or an in-law unit of your own, you might want to check out my new book, In-laws, Outlaws, and Granny Flats: Your guide to turning one house into two homes Or you can visit my site to get a preview of some of the book's photos at www.cozydigz.com
Mike Litchfield was a founding editor of Fine Homebuilding who has been renovating homes or writing about them for more than 30 years. His opus magnus, Renovation: A Complete Guide, is in its 3rd Edition. Mike is also a Certified Green Building Professional.
© Michael Litchfield 2011
Image Credits:
- Mike Litchfield
- Stephen Shoup
- Muffy Kibbey
Tue, 03/01/2011 - 15:06
Taya and Stephen, applause
by aj builder, Upstate NY Zone 6a
Taya and Stephen, applause applause applause...
Proud of you two for your daring and talent in living large in a small space.
Thu, 03/03/2011 - 13:58
and more applause
by Matthew Amann
Nice work, modular building combining recycled and renewable materials, now that's GREEN.
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Comments
