Factory-Built Wall Panels
Panelized construction allows walls to be built in a controlled environment and speeds the construction schedule
Image 1 of 4
The exterior wall of our double-stud wall assembly will sit on the foundation. This method provides a pocket for cellulose insulation which protects the exterior of the rim joist.
[Editor's note: Roger and Lynn Normand are building a Passivhaus in Maine. This is the 25th article in a series that will follow their project from planning through construction.]
Even though the concrete is still fresh in the Logix ICFInsulated concrete form. Hollow insulated forms, usually made from expanded polystyrene (EPS), used for building walls (foundation and above-ground); after stacking and stabilizing the forms, the aligned cores are filled with concrete, which provides the wall structure. block foundation, and the material for the main floor deck has yet to arrive, it’s time to think about walls.
Our main floor walls are not structurally complicated. The illustration at right shows a cross section of the walls.
The floor plan consists of four rectangles and one trapezoid joined together to form a tilted “T.” We will use 24-inch-on-center studs, with 2-stud corners to maximize the insulation cavity. We’ve got lots of big windows on the south side of the house that will use headers made of standard LVLLaminated veneer lumber. Engineered wood product in which wood veneers are glued together in thick sections for use as beams or other structural members. LVL is stronger, straighter, and less prone to warping or shrinkage than conventional lumber and does not require the destruction of mature trees. (laminated veneer lumber). All exterior walls are framed with 2x4 studs, except for the garage which is framed with 2x6 studs.
Huh? The house is framed with 2x4s but the garage uses 2x6 studs?
Yes. We hate getting into a cold car on a winter morn, and wanted the extra depth of a 2x6 wall to better insulate the garage.
The walls will be 14 inches thick
I should also say that the exterior wall on the house is really a double-stud wallConstruction system in which two layers of studs are used to provide a thicker-than-normal wall system so that a lot of insulation can be installed; the two walls are often separated by several inches to reduce thermal bridging through the studs and to provide additional space for insulation., i.e., two parallel 2x4 stud walls spaced 7 inches apart. (Building geeks call the outer wall the exterior wythe, and the inner wall the interior wythe). Our outer wall is load bearing. The 7-inch spacing between the outer and inner wythe, plus the 3 1/2 inch depth of each wythe, gives EdgewaterHaus a 14-inch-deep cavity that we will completely fill with aptly named dense-packed cellulose, for an R-53 exterior wall.
RELATED ARTICLES
GBA Encyclopedia: The Building Envelope
An Architect’s Take on Sweden’s Factory-Built Houses
Cost-Effective Building Options for High Performance Homes
Net-Zero For a Competitive Price
BLOGS BY ROGER NORMAND
Finished Foundation and Floor Framing Uh-Ohs
Placing Concrete In Our ICF Foundation Walls
Construction Begins — and We Encounter a Few Snafus
Do We Really Need 12 Inches of Foam Under Our Slab?
Passive House Certification: Looking Under the Hood
Backup Electrical Power for a Passivhaus Project?
Can We Get More and Pay Less To Keep About The Same?
Most homes are “sticked-framed” on site. After the main floor deck is in place, the lumberyard delivers a mountain of 2-by lumber and sheathingMaterial, usually plywood or oriented strand board (OSB), but sometimes wooden boards, installed on the exterior of wall studs, rafters, or roof trusses; siding or roofing installed on the sheathing—sometimes over strapping to create a rainscreen. to the job site. A framing crew then spends weeks cutting studs, assembling wall sections with exterior sheathing on the floor deck, and lifting the completed wall panel into place. They brace and nail the panel to the floor deck, then start on the next wall section.
I think there’s a better way to frame a building, one that can speed the process, improve quality, reduce waste, and perhaps save money.
Our wall panels will be built off-site
Somewhere between manufactured housing (completely built in a factory) and typical stick-built homes lies panelized walls built in a factory. The wall panels are then trucked and erected on site. Some panelized walls can include electrical, plumbing, insulation and exterior and interior finishes. We chose the more modest approach of factory-built studs and sheathing only.
There were a couple of nearby companies that panelize walls. We chose Hancock Lumber in Windham, Maine.
The advantages of panelization
I think factory-built walls have many advantages over stick-built walls:
Reliable, predictable assembly time. The panels are built in a controlled environment unaffected by weather delays. The panels are delivered on the day needed, ready for immediate assembly.
Concurrent wall production. It takes six or more months to build a home. Many parts of the construction schedule are sequential; one of the longest is wall framing. Factory-built walls panels are built concurrently offsite without interfering with onsite construction.
Quality. The wall panels are designed using 3D CAD software with error-checking software. We splayed most window rough openings to maximize daylightingUse of sunlight for daytime lighting needs. Daylighting strategies include solar orientation of windows as well as the use of skylights, clerestory windows, solar tubes, reflective surfaces, and interior glazing to allow light to move through a structure. the interior. We wanted our interior walls 5/8 inch shy of the ceiling plane, so we could apply 1/2-inch plywood across the ceiling plane to conduct our first blower-door testTest used to determine a home’s airtightness: a powerful fan is mounted in an exterior door opening and used to pressurize or depressurize the house. By measuring the force needed to maintain a certain pressure difference, a measure of the home’s airtightness can be determined. Operating the blower door also exaggerates air leakage and permits a weatherization contractor to find and seal those leakage areas..
We also cut 5/8 inch from the length of interior walls that intersect the inner wythe, so that we could later slide drywall through the intersection to achieve an airtight drywall installation. (We gleaned this detail from an excellent article on airtight drywall by Myron Ferguson in the Aug/Sept 2012 issue of Fine Homebuilding Magazine.)
The CAD software helps to visualize how all these walls come together, and automatically produces a detailed cut list. A specially equipped workshop and an experienced crew like at Hancock Lumber can consistently and efficiently produce high-quality wall panels.
Much faster building dry-in. When combined with factory-built roof trusses, the framing crew can erect and dry-in the entire building in a matter of days, not weeks or months. That reduces the likelihood of framing delays affecting the scheduling of future tasks.
Less exposure to weather. Completing the building shell quickly reduces the likelihood of weather damage from mold, mildew, warping, or delamination of sheathing.
Environmental. There is likely much less waste. Because wall panels are built every day, cutoffs that would otherwise be thrown away can be used for other wall panels. It is also much easier to capture and recycle sawdust and short framing pieces.
Worker ergonomics. The panels are assembled on a waist-high table. No bending down to floor level to nail the top and bottom plates to the studs.
Theft concerns. There’s not a tempting stack of lumber or plywood on site for weeks that tempts someone to “borrow” a few pieces.
But the foundation has to be perfect
Panelized walls is not, however, a panacea.
The method places a premium on the foundation. The wall panels are built according to the architectural plans, under the expectation that the “as-built” foundation and floor deck will also achieve the same level of precision. A stick-built wall can more easily accommodate foundation and decking irregularities.
The method limits adjustments. Once in production, panels can’t be easily re-framed if the owner wants to subsequently relocate a door or window.
Are there any cost savings?
Does panelized walls save money? I believe so. A 2011 study commissioned by the province of Alberta, Canada, compared construction of two identical side-by-side homes: one was stick-built and the other used panelized walls. The panelized home had a 40% shorter build time, 55% less lumber waste, 60% less sheathing waste.
We started working with Gary Plourde, director of the Panelized Wall section of Hancock Lumber, last year and have been exceptionally pleased with his professionalism and insight.
I recently drove to Hancock Lumber in Windham to watch Gary and his crew build the wall sections for our main floor, garage, and three-season room. I was very impressed with how the wall panels were designed and assembled. I’m amazed more homes don’t use factory-built walls.
Check out this video of the process. Check in with us later to see whether the “as built” foundation and floor deck meet the design expectations!
The first article in this series was Kicking the Tires on a Passivhaus Project. Roger Normand's construction blog is called EdgewaterHaus.
Image Credits:
- Chris Briley
Tue, 03/12/2013 - 16:31
I have done a lot of factory
by Richard Patterman
I have done a lot of factory built wall panels on multi-family and production housing.
I can not see how it would be cost effective on a one of a kind custom home.
If you include the owners, builders, framers and architects time in co-ordinating the factory build walls you will find it to very expensive. As far as saving time, I have found the wall framing to be a very small part of the whole job. Also will you have to add the cost of a fork lift or crane?
Tue, 03/12/2013 - 16:59
"The panelized home had a 40%
"The panelized home had a 40% shorter build time, 55% less lumber waste, 60% less sheathing waste."
I don't buy these numbers. Panelized walls do not provide 40% shoter build time (foundation to carpet)
They can not even reduce "framing time" 40% since walls are maybe 40% of a frame job. And material waste is a function of a smart GC and framer, not where the wall is framed.
Tue, 03/12/2013 - 21:14
Math, panelizing
by Dan Kolbert
Roger - you say you've got a 9" space and 2@2x4 walls for 14" - did you mean 7" space? Or 16" walls?
And I'm looking to build a house this spring and we also are looking to panelize it. We found it to be cheaper and faster as well, although not by as great a factor as you did. We also have a small (and middle-aged) crew and decided it was a good way to leverage our resources.
Wed, 03/13/2013 - 09:04
casement windows
by shane claflin
Why did you opt for casement windows?
Thu, 03/14/2013 - 22:37
Roger responds
by Roger Normand
I should have included a link to the Province of Alberta study. Here it is:
http://www.solutionsforwood.ca/_docs/reports/BuildAlbertaBrochurefinal.pdf
There as no cost for a fork lift or crane. The panels were readily moved by the framing crew.
Dan, thanks for catching the math error (note to my editor Lynn!) The walls are indeed 14" deep, so there's a 7" space between the studs.
We chose casement windows because they are more energy efficient than other types, and we like the clean lines vs double hung.
Fri, 03/15/2013 - 04:30
Thanks, Roger
Roger,
Thanks for your comments. I have edited the text of the article to reflect the 7-inch spacing between the 2x4 walls and to include the link to the Alberta study.
Sat, 03/16/2013 - 10:26
Seen the results
by Aaron Gatzke
I live in a new area of Edmonton, Alberta. While most homes are stick built, I have seen several that are panelized construction. It usually takes two days. When I leave for work in the morning, there will be a flatbed of panels on the jobsite. All of the panels have 2 to 3 inches of factory applied spray foam insulation. On the first day, they assemble the roof on the ground. By the end of the second day, there is a completely framed home. And this is in the dead of winter.
Sun, 03/17/2013 - 22:34
Panelized experience in PH
by albert rooks
Dan,
We are about 5 projects in on panelization. We really like it for speed and quality. We've not made any great claims on economics but I think it really improves the project quality and the ability to work around the year in the PNW cold wet climate.
Part of the economic issue is the "one off factor" for sure. But I'm convinced that we could grow into better economics as we get better at defining and repeating our assemblies.
The range so far has been 12" to 16" thick diffusion open to the exterior panels 10' to 12' x up to 25' feet long. Working the site and the assemblies at the same time is a real benefit.
Here is a short video of a first floor being set in an afternoon. It's a satisfying accomplishment and effort. http://www.youtube.com/watch?v=HOND3BT4f9c&sns=em
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Comments
