Looking Through Windows — Part 5
Using Unilux windows from Germany, we’re there — but just barely
Unilux window with thermal breaks in the sash and frame. [Photo credit: Linda Whaley, Small Planet Workshop]
[Editor's note: Roger and Lynn Normand are building a Passivhaus in Maine. This is the ninth article in a series that will follow their project from planning through construction.]
Strike up the band: we have – finally – achieved the Passivhaus standard with Unilux windows!
Marc Rosenbaum, our energy consultant, ran the Passive HouseA residential building construction standard requiring very low levels of air leakage, very high levels of insulation, and windows with a very low U-factor. Developed in the early 1990s by Bo Adamson and Wolfgang Feist, the standard is now promoted by the Passivhaus Institut in Darmstadt, Germany. To meet the standard, a home must have an infiltration rate no greater than 0.60 AC/H @ 50 pascals, a maximum annual heating energy use of 15 kWh per square meter (4,755 Btu per square foot), a maximum annual cooling energy use of 15 kWh per square meter (1.39 kWh per square foot), and maximum source energy use for all purposes of 120 kWh per square meter (11.1 kWh per square foot). The standard recommends, but does not require, a maximum design heating load of 10 W per square meter and windows with a maximum U-factor of 0.14. The Passivhaus standard was developed for buildings in central and northern Europe; efforts are underway to clarify the best techniques to achieve the standard for buildings in hot climates. Planning Package (PHPP) energy modeling software and arrived at a heat load of 4.74 KBTU1,000 Btus/sq. ft./year, a mere 0.01 below the 4.75 limit. Talk about a photo-finish squeaker!
Yes, being just 0.01 below the limit is too close for comfort. Marc has entered several PHPP assumptions that, upon review by a still-to-be determined independent Passive House certifier, may be modified or disallowed. I will discuss in a future blog additional steps we can consider to further lower the annual heat load and provide flexibility for the certification review. Still, we are very pleased that the EdgewaterHaus design is sufficiently robust to meet the Passive House heat load standard, which is much harder to attain in a northern climate than the primary energy criteria.
Are the windows Passivhaus-certified?
A Passivhaus building relies on the sun as the primary engine to heat the house. South-facing windows play a critical role. Today’s blog explores why using Unilux windows has been so challenging, and how changes of just one tenth or even a few hundredths of a percent in window performance specifications, changes seemingly so minute that they would appear to be inconsequential except in judging the performance of an Olympic athlete, yield significant energy performance consequences.
RELATED ARTICLES
Kicking the Tires on a Passivhaus Project
Selecting a General Contractor
Plans and Pricing for Our House in Maine
Looking Through Windows — Part 1
Looking Through Windows — Part 2
Looking Through Windows — Part 3
Looking Through Windows — Part 4
Looking Through Windows — Part 6
Looking Through Windows — Part 7
The Unilux sales brochure boldly proclaims that the window we selected, the UltraTherm 3, “exceeds the Passive House standard.” So when we first saw the window and liked it very much, we figured it would easily meet our needs for EdgewaterHaus. After three tortuous months of fitting and fine-tuning these windows to our situation, I can offer a qualified “Yes, but...”
We failed to notice an early clue of the challenge ahead: notwithstanding the Unilux claim, the UltraTherm 3 window does NOT carry a Passivhaus certificate like the Schüco window we also considered. (The Passivhaus Institut in Germany tests and certifies certain products like windows and heat-recovery ventilators on their suitability for use in Passivhaus buildings.)
Certified products feature exceptional energy performance, making it easier for a designer to select key building components to attain the Passivhaus standard. (But only if the designer can read German! You see, the Passivhaus Institut and the Passive House Institute U.S. have been so busy feuding with each other that neither has taken the time or effort to offer users an English translation for certified products!) Hmm.
Window woes
Adding to the challenge was the poor technical support we have received from Hancock Lumber, the local distributor for Unilux windows. Following my previous blog on “window woes,” we met with the president of Hancock Lumber to discuss our concerns about the firm’s lack of technical product knowledge and lengthy turnaround times, but unfortunately that meeting has not led to a discernible improvement.
We have had 10 repricings on windows over some four months, most of which I believe could have been avoided if the Hancock team were true salespeople who grasped what our needs were and had the depth of product knowledge to recommend what Unilux configuration would best serve our purposes.
To this day, I don’t believe the Hancock window team realizes that it’s not just about sizing glass to fit into a wall opening, but engineering a high-performance window solution to heat a home.
We need R-118 insulation and more south-facing glass
So how did we get to the 4.74 KBTU/sq. ft./year? There were a few enhancements to the building envelopeExterior components of a house that provide protection from colder (and warmer) outdoor temperatures and precipitation; includes the house foundation, framed exterior walls, roof or ceiling, and insulation, and air sealing materials. and a concerted effort fine-tuning the windows.
To improve the overall building thermal performance, our architect, Chris Briley, added more south-facing glass and reduced the roof overhang above these windows to eliminate any winter shading. Chris assures us that the vegetative trellis he has designed along the south facade will preclude overheating in the summer. (Don’t architects guarantee the integrity of all aspects of their design?) The vegetation will die in the winter, allowing full sun to enter the home.
Marc Rosenbaum then added 10 inches of cellulose insulationThermal insulation made from recycled newspaper or other wastepaper; often treated with borates for fire and insect protection., raising the ceiling R-valueMeasure of resistance to heat flow; the higher the R-value, the lower the heat loss. The inverse of U-factor. from R-76 to — gasp — R-118.
But Chris had to literally stumble onto two key changes to the Unilux windows, overcoming initial “no can do” from the Hancock team: specifying (1) “direct glazing” and (2) optional higher SHGCSolar heat gain coefficient. The fraction of solar gain admitted through a window, expressed as a number between 0 and 1. glazing.
Normally two adjacent windows each have their own frames and sash surrounding the glazing. But sashes at ~ R-1 have a much lower insulating value than does the triple-pane glazing at R-5 or higher. Direct glazing allows a single sash to hold two adjacent pieces of glazing. Eliminating one sash between two abutting windows means more higher performing glass, less poorly insulating sash, and thus better overall performance for the entire window assembly.
The Hancock Unilux team initially said that direct glazing was not possible. Kudos to Chris for his persistence in getting confirmation from Unilux that direct glazing was indeed possible and beneficial.
Is high-solar-gain glazing available?
Similarly, Chris had to ask why Unilux could not provide higher SHGC glass like that offered by some of their competitors. (Note: the Solar Heat Gain Coefficient(SHGC) The fraction of solar gain admitted through a window, expressed as a number between 0 and 1. measures how much solar gain penetrates the windows. A high SHGC allows more of the solar radiant heat to pass through the glass into the house. A high SHGC is desirable for northern climates, while a low SHGC is better for southern climates where cooling is more important than heating.) Remember that a Passivhaus building is designed to use south-facing windows as the primary heat source for the home.
Of all the adjustments that were made, specifying higher 0.61 SHGC glass vs. the Unilux-supplied 0.5 had the greatest impact on building performance; yes, more important than even the U-factorMeasure of the heat conducted through a given product or material—the number of British thermal units (Btus) of heat that move through a square foot of the material in one hour for every 1 degree Fahrenheit difference in temperature across the material (Btu/ft2°F hr). U-factor is the inverse of R-value. or the 10 inches of additional cellulose insulation in the ceiling.
Higher SHGC is not a standard Unilux option, but Unilux was willing to obtain and install this glazing in our windows. I find it surprising that a premium European window manufacturer like Unilux does not include high-SHGC glazings in its repertoire.
Small changes in the SHGC matter
Which gets to what I call the importance of “two-decimal place accuracy” on window performance specifications.
This table (Window Comparison) compares the performance specifications for the four windows we seriously considered for EdgewaterHaus. Look at the SHGC for the triple-pane windows, which range from a low of 0.5 for the standard Unilux glazing to a high of 0.64 for the Thermotech. That’s a spread of only 0.14. How can such a tiny change in heat gain have much of an impact, you ask? I was just as puzzled.
So here’s a simple summary of Marc Rosenbaum’s PHPP heat-load analysis that compares the net heat flux for all Unilux windows within the building envelope (e.g., it excludes windows in the garage and three-season room). Net heat flux is the average annual solar heat gain during the day for our geographic location less the heat loss in the evening. All numbers are positive, signifying that the windows admit more solar gain than they lose (Passivhaus buildings rely on windows to heat the home, so this should not be surprising):
- 7,716 KBTU/year using Unilux 0.5 SHGC windows prior to the above changes.
- 10,075 KBTU/year with the above changes but retaining 0.5 SHGC windows.
- 14,817 KBTU/year with the above changes, including the higher 0.61 SHGC glazing on main floor south facing windows, standard 0.5 SHGC on all other windows.
The benefit of higher SHGC glass outweighs the slightly poorer glazing U-factors. For the Unilux windows, the high-SHGC glass has a U-factor of 0.109, while the standard glass has a U-factor of 0.088 (lower U-factors indicate better peformance). That’s because the higher SHGC allows more heat to enter than the poorer U-factor loses.
The table also suggests why the Pella Proline windows which we previously considered and liked so much fared so poorly in the PHPP analysis. Pella offers a much less competitive SHGC of 0.0558 AND poor U-factor of 0.171
Although both Pella and Unilux are wood-framed windows, the Unilux window incorporates a proprietary thermal break within the wood core (see the photo above) of the frame and sash, substantially improving the U-factor compared to the Pella window.
An arm and a leg
Wondering whether these Unilux windows are expensive? With its exquisitely engineered high-tech framing, heavy-gauge aluminum exterior claddingMaterials used on the roof and walls to enclose a house, providing protection against weather. , interior stained wood, triple-pane glazing with optional (read more costly) high SHGC glazing that still manages to easily open and close on robust door quality hinges, the answer is unequivocally “yes.”
At a cost of $113 per square foot of glazing, that is just short of outrageous, and seriously challenges our checkbook. We could save perhaps $20,000 by going with triple-pane Thermotech Fiberglass or Schüco windows. We would get equivalent performance, at least initially. But having examined the Thermotech and Schüco windows very closely, I am certain we would not get the long term durability, nor the esthetic beauty of the Unilux windows.
It’s a shame that the technical skills of the local Unilux distributor are not on par with the premium Unilux window they are selling. Hopefully, Hancock Lumber is now be better informed to help future clients.
The first article in this series was Kicking the Tires on a Passivhaus Project. Roger Normand's construction blog is called EdgewaterHaus.
Image Credits:
- Linda Whaley, Small Planet Workshop
Wed, 09/26/2012 - 16:36
North American U values versus European U Values
by Mika Laspa
Thank you for your article.
I’m all for more robust window systems but do have a question about the table you referred to that compared window systems.
In the table where you compared U values and SHGC had you considered the different methodologies used to obtain the values
U values:
In Europe they use a range of approximately 0 degrees C to + 20 degrees C.
Under NFRC (North America) they use a range of approx -20 degrees C to + 20 degrees C.
Wed, 09/26/2012 - 17:13
Response to Mika Laspa
Mike,
For more information on this topic than you knew existed, see this Q&A post, as well as the 29 informative answers posted below the original question: European windows vs. North American windows.
Thu, 09/27/2012 - 01:17
i know this is an older post,
by mike eliason
i know this is an older post, but the PHI's website does contain english copies of the certifications. the bigger issue is that even in the 4 years of PHIUS's good standing w/ PHI, there was never any real progress on this front. It's good to see APHN and PHI teaming up to resolve this significant leadership gap with the window certification workshop at greenbuild this year.
with the price that high - was there any discussion of using pazen or optiwin? we've had optiwin quotes come in well south of that with some really phenomenal glass.
Thu, 09/27/2012 - 18:17
What about reflectors and window placement?
by Derek Roff
Given the importance of a 0.1 difference in SHGC reported in the article, I wonder about the significance of window placement, nearby trees, plants, and buildings, and reflective surfaces near the windows. I've read figures that a deciduous tree or shrub will block 20-30% of the light, even when it has no leaves. If this is true, can we count on the architects guarantee of the benignity of the "vegetative trellis"? Would not a few minutes of shading per day from some quantity of branches and twigs overshadow the difference between a 0.5 and 0.61 SHGC rating?
A second-story window above a grassy incline gets no significant reflected light. A ground floor window next to a light-colored deck will conduct a substantial amount of reflected light into the home, and even more from clean snow. Wouldn't some wise choices on reflective surfaces have an impact similar to the differences in SHGC values discussed in this article?
I recognize that many home owners are not willing to deal with moving shades, overhangs, and reflectors twice a year. To me, movable shading is a useful part of the energy efficiency and comfort equation. Especially since the ambient temperatures are seasonally out of phase with the sun angles, in most locations. Two months before the solstice, in April, I may still want to maximize solar gain, while two months after it, in August, I may want all the shade I can get.
Thu, 09/27/2012 - 21:00
Article converts me to Pretty Good House Standard
by William Rau
As much as I admire the Passivhaus standard and how it has raised the bar for green building in the US, this article has convinced me that the Pretty Good House Standard is the way to go. Of German ancestry, I have a deep respect for German craftsmanship and truly appreciate their remarkable doors and windows. When I visited Germany this spring I could only marvel at their "ka-chick," vault-like doors -- truly remarkable!
At the same time, I am a cost-conscious pragmatist. What I see at work here is a financially irrational numbers game. I'd rather build a Pretty Good House and use the money saved to help launch a communal solar or wind farm. We're facing a global meltdown and capital will become increasingly dear. In this larger context -- the coming global crisis -- wasting money in pursuit of a numbers game doesn't make much sense. The Germans know this and have poured the lion's share of their spare resouces into creating renewable energy infrastructure.
We have to make every dollar count, as the Germans do by going for the greatest bang for the buck.
Sat, 09/29/2012 - 10:29
Thermal breaks
by Aaron Gatzke
Could you point out what the thermal breaks look like?
Is it the lightest coloured part that you see?
Thanks,
Aaron
Sat, 09/29/2012 - 19:25
PH or PGH?
by Steve Young
I am not quite ready to give up on the PH concept, but the more that I learn, the more that I need to research. It is such a complex model, with far too many inputs. If money were no object, sure, I would pay someone to design my house, but as a near-DIY, I don't have the patience to track down all the details required to determine the cost effective way to build a PH. (I have a Certified Passive House person that is willing to run the Planning Package, but I would like to do as much legwork as I can)
We shouldn't have to scratch and claw details from the window manufacturers, or any other supplier of high quality building products.
And then there is the whole question as to which numbers do you use in the PHPP. We know that European numbers don't correspond to N American window numbers, so how much faith do you put into the outputs of the PP?
I certainly like the PH concept, but the PGH seems a who lot less complex, and probably less expensive.
Steve Young, just running on while enjoying a home brew
Mon, 10/01/2012 - 08:44
Response to Aaron Gatzke
Aaron,
A thermal break is any material (usually a type of insulation material) with a high enough R-value (that is, a low enough U-factor) to reduce the rate of heat transfer through a structural element.
In the photo, the white-colored materials and the yellow-colored materials are thermal breaks. These thermal breaks are surrounded by glued pieces of wood. The core materials have a lower U-factor than the wood that surrounds them.
I'm not sure what materials these are; perhaps someone familiar with the Unilux frames and sash can let us know.
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Comments
