QA-spotlightheader image
1 Helpful?
How to Keep Garage Fumes Out of the House
If the house has an exhaust-only ventilation system, will fumes be drawn inside?
Posted on Apr 4 2011 by ScottG
Jack Woolfe wants to build a small, airtight house with an attached garage. The house will have an exhaust-only ventilationMechanical ventilation system in which one or more fans are used to exhaust air from a house and make-up air is supplied passively. Exhaust-only ventilation creates slight depressurization of the home; its impact on vented gas appliances should be considered. system, meaning the system will expel stale air from the house without providing a specific source for replacement air.
That's one of several options for whole-house ventilation, but Woolfe is weighing the possible risks.
"I'm concerned that the negative pressure in the house may draw unwanted fumes in from the garage," he writes in a post at GreenBuildingAdvisor's Q&A forum. "Are there any recommendations for supplying makeup air to the house so that there isn't negative pressure in the house, or perhaps a well-sealed door between the house and the garage? Any other ideas, besides a HRV(HRV). Balanced ventilation system in which most of the heat from outgoing exhaust air is transferred to incoming fresh air via an air-to-air heat exchanger; a similar device, an energy-recovery ventilator, also transfers water vapor. HRVs recover 50% to 80% of the heat in exhausted air. In hot climates, the function is reversed so that the cooler inside air reduces the temperature of the incoming hot air. system or a detached garage?"
Woolfe's question is the subject of this week's Q&A Spotlight.
Consider occupant-sensing ventilation
Peter Smith suggests Woolfe consider something called occupant-sensing ventilation, available through Conservation Technology. The company describes it as a "continuous, multiport, exhaust-only" system. An efficient exhaust fan is connected to bathrooms, laundry and kitchen with a trunk duct and motion-sensing exhaust grilles. When the rooms are unoccupied, airflow rates are modest. When a room gets too humid or is occupied, airflow rates jump sixfold.
John Klingel has two additional ideas: install a high-capacity fan that starts up whenever the garage door is opened and runs for 20 minutes. The system would have an inlet for fresh air specifically for the garage. And second, Klingel suggests, install the door between the house and the garage so it opens into the garage. That way, any negative pressure in the house will draw the door more tightly closed.
Or, make the garage a detached structure
"If it's not too late," says GBA senior editor Martin Holladay, "consider a detached garage. Even a garage connected by a short breezeway is safer than an attached garage."
No doubt this is true. Given the variety and toxicity of stuff that often ends up in the garage, keeping the structure safely away from an airtight house sounds like good advice.
Except that Woolfe is counting on it.
"Martin, you must feel strongly in favor of a detached garage," he says. "I really like the idea of the garage and the house sheltering and warming each other, and the sharing of the common wall means less foundation, framing, roofing and claddingMaterials used on the roof and walls to enclose a house, providing protection against weather. . Sure would like to find a way to have my cake and eat it too."
John Linck agrees. "I built my home with a long tandem attached garage along nearly all the cold northern exposure, with attic above," he says. "The savings in materials and energy help to green the whole, if having a garage at all can really be considered green. "I also turn off my Prius when it's in the garage so any fumes are very temporary and certainly don't approach dangerous levels. The garage is totally sealed from the living space, 5/8-inch fire-rated drywall, fireproof steel entry door, etc."
The Prius factor? Linck isn't the only one to have a hybrid car. "I've found that with our hybrid car we can back out and close the overhead door before the gas engine ever kicks on," writes Kevin Dickson.
But not everyone owns an electric vehicle, and there also are the many solvents, fuels, adhesives, finishes and other potential sources of foul air in a garage. And, Linck adds, if you're a fan of starting your car with a remote device, you're probably better off with a carport.
"If your memory is like mine, you might start it and forget it," he says. "My CRS syndrome is getting worse every year."
Is this any way to heat a garage?
Woolfe may be a fan of green building, but what he's really after is staying comfortable in his garage, not necessarily greening "the whole thing," as Linck had suggested. "Green?" he asks. "Who's talking green? I'm mostly interested in avoiding white — as in white fingers when working on my car in the winter!"
James Morgan can sympathize, but adds this: "It doesn't sound very smart or effective to rely on leakage from the house through an inadequately insulated common wall to heat your garage. It's only leaky homes that have made attached garages an acceptable arrangement. Tight homes demand a different standard."
"James, I don't plan to rely on heat leaking from the house to heat the garage," Woolfe says. "The garage will be cold unless I specifically heat it, just not as cold as it would be with four walls exposed to the weather, instead of three walls. Likewise, one wall of the house will be warmer because it will be buffered by the garage."
Heat is definitely a factor. Holladay argued in a previous exchange that basements are far more useful than garages. "Garages freeze; basements don't," he wrote. "You can't store a bucket of drywall mud in a garage."
Our expert's opinion
Here's how Peter Yost, GBA's technical director, views it:
While the air-sealing details to isolate an attached garage are not easy, they work. For more, see How to Build an Energy Star Home: Building Plans for the Thermal Bypass Checklist. Diagnostic testing can confirm how effective this is.
An excellent workshop by Keefe, Cox, and Williams on the principles, techniques, and procedures for isolating attached garages was presented at an Affordable Comfort conference: The Garage Connection: Solving Indoor Air Quality and Comfort Problems.
I have to admit, I have been pretty dead-set against the idea of attached garages from an indoor air quality perspective, but the sheltering and material savings associated with an attached garage are compelling. If the garage is isolated outside the conditioned boundary, the door to the house is airtight and swings outward, and a dedicated exhaust fan on a trigger and timer is installed. Sure seems as though our GBA crew, collectively, has nailed this one.
Tags: , ,
Image Credits:
  1. Don Mannes Fine Homebnuilding #162
1.
Apr 6, 2011 3:27 PM ET
Garageaholic
by C6ZFLWjfsU
In my past three homes, all of which had drywalled and insulated walls, here in Denver where it sometimes drops to 20 below, I've never had the temperature drop below 35 degrees, as the engine block heat keeps the space above freezing. Still not a good idea to store paint in there, as one day I'll forget to put the door down. On this home, I put in a through wall bath fan on a motion sensor switch, that detects any movement, auto or pedestrian, and kicks the fan on for 30 minutes. No separate inlet; I'm relying on the leaks in the insulated garage door weatherstripping.
2.
Apr 9, 2011 3:06 PM ET
Please try cheap Central Fan Integrated Supply ventilation
by u5XaeYJGMY
Jack, I am so glad you are asking about the make-up air side of ventilation too. I’m glad to share my solution. I wanted to get controlled fresh air 24x7 plus slightly positive air pressure to help with indoor air quality. Along the way I learned that HRVs do not add supply make-up air – they only replace what they take out. I found this GBA article was very helpful: “Designing a Good Ventilation System: Ventilating Is Easy — It’s Ventilating Right That’s Hard (Musings of an Energy Nerd, Martin Holladay, June 15 2010). It helped me validate a decision to use Central Fan Integrated Supply (CFIS – my abbreviation) for my very tight and efficient house. I found very good information plus cold and warm region CFIS approaches from Building Science Corporation (buildingscience.com). GBA staff collaborates with BSC staff to provide super well-reasoned advice. Check out RR-0304: Central Fan Integrated Supply Ventilation—The Basics. There’s additional articles from there – the BSC search bar works well. I chose the Aprilaire 8126 ventilation controller/damper integrated with an Aprilaire dehumidifier, but there are other installation options. For apples-to-apples comparison, the 8126 is $100+ and installation of insulated ductwork and integration into my HVAC was an additional $300 (in Sept 2010) for my new home. CFIS brings fresh air into your return air plenum for mixing by your existing HVAC system. An important requirement is a high-efficiency ECM variable speed blower on your furnace. Make sure your heater choice has an efficient exhaust blower motor too, since both are running when venting, heating or cooling. Ventilation demand calls have to be calculated and programmed via your thermostat or other HVAC control method. I may find that I still want an HRV in the future. But for now I am very happy with a thermostat setting of 70 F and initial natural gas bills of $66 in January and February 2011 in Cleveland (for heating 3400 SF first, second, and basement plus gas cooking, and gas dryer).
3.
Apr 11, 2011 9:37 AM ET
Why not a monoxide detector that alarms in the home?
by MatthewKlein
I admit not being a fan of attached garages, although I know all of the benefits of having one attached. However, more than one person/family has been killed due to a car left running in the garage. Just this morning on a radio program, a young lady in her 70s admitted to forgetting that she once forgot that she left her car running in the garage. This past winter, a sheriff's deputy, who should know better, and his wife were killed due to a car left running in the garage. If the garage is made somewhat air tight, a person in the home might not even hear a car running in the garage. After all, one of the goals of car designers is to made quiet cars. Another possibility would be someone starting a car with a remote starter and just forgetting--we are such a distracted people after all--or someone else, say a child doing it without a parent knowing. And, I have also heard the tragic stories of a person who committed suicide, and negligent homicide of the rest of the family, by car in a garage.
I have never understood why, then, monoxide detectors in garages are not more popular. We have the technology to make detectors that sense in the garage and alarm in the home--even one that could do that wirelessly or using the home's wiring as transmission cables. We also have the technology to make detectors that can actuate a ventilation fan in the garage. We have them for commercial garages. So, why aren't they used for home attached garages? I find that strange because I hear far more stories of people dieing from monoxide poisoning in home garages than in commercial garages.
Become a GBA PRO!
