QA-spotlightheader image
0 Helpful?
Making the Case for Exterior Foam Insulation
In Climate Zone 3, is installing rigid foam on the exterior side of the wall sheathing worth the effort and expense?
Posted on May 29 2017 by Scott Gibson
Writing from Climate Zone 3, Farm House seems to have worked out many of the details for the dream house he plans to start building in a few months.
"Plan to live in it for 30+ years," he writes in a post at the Q&A forum at Green Building Advisor. "The house will have Zip System sheathingMaterial, usually plywood or oriented strand board (OSB), but sometimes wooden boards, installed on the exterior of wall studs, rafters, or roof trusses; siding or roofing installed on the sheathing—sometimes over strapping to create a rainscreen. and will be well insulated on the inside. I will just leave it at that. Not interested in installing rigid foam on the outside of the roof sheathing. (I have my reasons, so please don't try to convince me otherwise.)
"So, house fully exposed to sunlight. One inch rigid foam with foil facing. Strapped with fiber-cement siding."
That's the plan: no rigid foam on the roof, but 1 inch of rigid foam on the exterior walls, plus a vented rainscreenConstruction detail appropriate for all but the driest climates to prevent moisture entry and to extend the life of siding and sheathing materials; most commonly produced by installing thin strapping to hold the siding away from the sheathing by a quarter-inch to three-quarters of an inch. and siding.
The Farm House challenge? "Sell me on all the reasons this [rigid foam on the walls] is worth the time and cost."
Not our job to sell anything
"First of all," says GBAGreenBuildingAdvisor.com senior editor Martin Holladay, "it's your house. You can build it any way you want, as long as your local code enforcement official is happy. I don't see any reason to convince you of anything."
That said, if Farm House decides that it's a good idea to increase the R-valueMeasure of resistance to heat flow; the higher the R-value, the lower the heat loss. The inverse of U-factor. of the wall assembly or reduce thermal bridgingHeat flow that occurs across more conductive components in an otherwise well-insulated material, resulting in disproportionately significant heat loss. For example, steel studs in an insulated wall dramatically reduce the overall energy performance of the wall, because of thermal bridging through the steel. between the studs, he could take the advice of Steve Knapp and use Zip System insulated R-sheathing, which combines structural sheathing with foam insulation.
R-sheathing can take the place of conventional OSB or plywood sheathing. It comes in various thicknesses, with R-values ranging from 3 to 12.
"But I see no reason to try to convince you."
Skip the exterior foam and invest in PV
Dana Dorsett won't try to convince Farm House, either. He suggests using BEopt, free energy-modeling software available from the National Renewable Energy Laboratory. Then, given the good solar exposure that's apparently available on the house site, Farm House could compare the return on investment for spending the same amount of money he'd need for insulated sheathing for a rooftop solar array, calculated at $3 a watt before any subsidies.
"In U.S. Climate Zone 3, it's possible (with a decent design) to hit net-zero energyProducing as much energy on an annual basis as one consumes on site, usually with renewable energy sources such as photovoltaics or small-scale wind turbines. with 2x6 (R-20) walls, no exterior insulating sheathing, and with a PV array that fits comfortably on a sun-drenched house, using better-class heat pumpHeating and cooling system in which specialized refrigerant fluid in a sealed system is alternately evaporated and condensed, changing its state from liquid to vapor by altering its pressure; this phase change allows heat to be transferred into or out of the house. See air-source heat pump and ground-source heat pump. technology properly sized for the modest loads," Dorsett says.
He refers Farm House to a Building America research paper for more information. That study suggests that an R-20 wall in Climate Zone 3 — but times have changed.
"That document was created in 2009/2010, when PV cost $7-8/watt and was 15% efficient, whereas now it's $3/watt and ~20% efficient, requiring less rooftop real-estate to deliver the same amount of energy," Dorsett says. "And, better-class heat pumps at that time were running HSPF 10-12 with SEER(SEER) The efficiency of central air conditioners is rated by the Seasonal Energy Efficiency Ratio. The higher the SEER rating of a unit, the more energy efficient it is. The SEER rating is Btu of cooling output during a typical hot season divided by the total electric energy in watt-hours to run the unit. For residential air conditioners, the federal minimum is 13 SEER. For an Energy Star unit, 14 SEER. Manufacturers sell 18-20 SEER units, but they are expensive. in the teens, whereas current better-class ductless minisplits are in the HSPF 12.5-14 range, with SEERSeasonal Energy Efficiency Ratio (SEER) is the total cooling output (in BTU) of an air conditioner or heat pump during its normal annual usage period divided by its total energy input (in Watt-hours) during the same period. The units of SEER are Btu/W·h. SEER measures how efficiently a residential central cooling system operates over an entire cooling season. The relationship between SEER and EER depends on location, because equipment performance varies with climate factors like air temperature and humidity. well north of 20."
With those two advances in technology, Farm House could aim for the R-value recommendations that Building America suggests for a milder climate zone (Zone 2) and still hit net-zero performance. A 2x6 R-20 wall framed at 16 inches on center with a rainscreen gap between the sheathing and the siding would work; so would a 2x6 R-23 wall insulated with rockwool batts (but with no rainscreen).
"So, skip the exterior insulation and concentrate the investment where it pays more," Dorsett says.
Farm House might still consider the more rigorous Climate Zone 3 recommendations for other building assemblies, while aiming for a building envelopeExterior components of a house that provide protection from colder (and warmer) outdoor temperatures and precipitation; includes the house foundation, framed exterior walls, roof or ceiling, and insulation, and air sealing materials. testing at less than 1 air change per hour at 50 pascals in a blower-door testTest used to determine a home’s airtightness: a powerful fan is mounted in an exterior door opening and used to pressurize or depressurize the house. By measuring the force needed to maintain a certain pressure difference, a measure of the home’s airtightness can be determined. Operating the blower door also exaggerates air leakage and permits a weatherization contractor to find and seal those leakage areas., plus a heat-recovery ventilator(HRV). Balanced ventilation system in which most of the heat from outgoing exhaust air is transferred to incoming fresh air via an air-to-air heat exchanger; a similar device, an energy-recovery ventilator, also transfers water vapor. HRVs recover 50% to 80% of the heat in exhausted air. In hot climates, the function is reversed so that the cooler inside air reduces the temperature of the incoming hot air. . A simple house shape minimizing corners would also help.
Consider fossil fuel use
Brendan Albano asks Farm House to consider the benefits of reducing the use of fossil fuels: a better insulated building will need less heat, and less heat means a lower carbon impact.
"Reducing your use of fossil fuels (and other non-renewable resources) is an ethical choice from an intergenerational equity (a.k.a., ‘think of the children’) point of view," Albana writes. "If exterior insulation is an effective way for you to do this, then it would be ethically responsible for you to add exterior insulation.
"Whether or not that line of reasoning is important enough to you to justify the expense is a question only you can answer."
But the introduction of fossil fuels into the discussion raises additional questions, replies Dorsett.
"The ‘future generations/fossil fuel’ discussion can go a number of different ways," he says. "Higher wall performance can be had with lower initial and long-term carbon emissions by staying away from foam altogether (which has a very real carbon footprintAmount of carbon dioxide and other greenhouse gases that a person, community, industry, or other entity contributes to the atmosphere through energy use, transportation, and other means. ) and using cellulose as the cavity fill (which is net-carbon-negative and sequesters carbon), or rock wool (low carbon footprint relative to any foam) and/or using only electric HVAC(Heating, ventilation, and air conditioning). Collectively, the mechanical systems that heat, ventilate, and cool a building. equipment combined with renewables-only electricity (site sourced or purchased)."
A question of diminishing returns
Farm House has given some thought to the environmental impact of his new home and the need to reduce fossil fuel emissions.
"That's a given for me," he says, "but I don't have an unlimited budget and I am certain that at some point during an envelope design, one starts spending money for very incremental improvements in performance."
So, while recognizing that exterior foam insulation increases the whole-house R-value, the question is whether it makes "good sense." Farm House wants to know whether a radiant barrier he's apparently planning on including will offer the advantages he's hoping for.
Further, he asks, "Is increasing the stud-to-siding R-value from 6.5 to 13 going to have a significant impact? For example: What percentage of heat loss or gain is expected through the 25% of the exterior walls that's made up of 2x6 studs? (If it impacts the answer, my goal is to achieve between 1 and 2 ach50.)
"We all know that an internal combustion engine is an glorified air pump," Farm House continues. "The faster you can get the air to go from intake to exhaust, the better the performance. At some point, though, you're spending silly money to increase performance that can only be justified if you race NASCAR every weekend. Catch my drift?"
Questions about plans for a heat pump
Farm House says that he's planning on "spending some serious $$$" for a Trane XV20i variable-speed heat pump. Good idea? Maybe not, says Dorsett.
The smallest model of that air-source heat pumpHeat pump that relies on outside air as the heat source and heat sink; not as effective in cold climates as ground-source heat pumps. has a capacity of 2 tons, he says, and although it's able to modulate its output, it has a turndown ratio of about 2.5 to 1, Dorsett says, "which could be sub-optimally oversized" for a higher performance house of about 2,500 square feet in Climate Zone 3.
"In a new house design, it's not super hard to hit the 2,500-square-feet-per-ton of cooling range, and even a code-minimum house can hit the ton per 2,000 [square foot] range, even with full sun exposure," Dorsett says. "The minimum modulated output of the 2-ton Trane XV20i is about 10,000 BTUBritish thermal unit, the amount of heat required to raise one pound of water (about a pint) one degree Fahrenheit in temperature—about the heat content of one wooden kitchen match. One Btu is equivalent to 0.293 watt-hours or 1,055 joules. /h at 95°F outside and even higher at lower outdoor temps. That means it can't really modulate at high efficiency if your load at your 1% design condition is only 12,000-15,000 BTU/h."
He adds that the "framing fraction" of 25% in exterior walls would account for roughly half the total heat transfer in walls.
"But the walls are only a fraction of the total heat gainIncrease in the amount of heat in a space, including heat transferred from outside (in the form of solar radiation) and heat generated within by people, lights, mechanical systems, and other sources. See heat loss. and heat loss, and with 2x6/R-20 construction staying at code-minimum, ... the total window area can account for as much heat transfer as the total wall area (or more)," Dorsett says. "These sorts of issues are why modeling the house with BEopt can be useful, since you can then determine the bang-for-your-buck of different component upgrades."
Another approach with Zip-R sheathing
Dorsett has one more idea for reducing thermal bridging without the use of a continuous layer of foam. Farm House could start with conventional framing using 2x4s. Then, rip sheets of 2-inch Zip R to widths of 1 1/2 inch and 3 inches, and glue them to the inside of the framing to create a total stud wall depth of 5 1/2 inches. (The 3-inch strips are for doubled-top plates and other areas where studs are doubled.) Use conventional insulation designed for a 2x6 wall.
"That brings the framing fraction up from about R-4.2 to about R-14, cutting the heat transfer through the 2x4 framing by more than 2/3, and the whole-wall performance improves by about 15% compared to a 2x6/R-20 wall at the same wall thickness," Dorsett says.
The idea is derived from an article by Stephen Bonfiglioli in Fine Homebuilding magazine.
Following up on Dorsett's suggestion, Gordon Franke writes that he ran some calculations on heat flow comparing the Bonfiglioli wall to several other options (see image #2, below).
"If my calculations are correct, the Bonfiglioli [wall] insulates better than a 2x4 wall with 1 1/4 inch of exterior insulation," he says. "One might say, ‘Well, 1 1/4 inch is too thin.’ However, a 2-inch layer only buys you a 3% improvement compared [to] the Bonfiglioli wall.
"In my own renovation, I can implement the Bonfiglioli wall myself over a couple of weekends for the cost of some EPSExpanded polystyrene. Type of rigid foam insulation that, unlike extruded polystyrene (XPS), does not contain ozone-depleting HCFCs. EPS frequently has a high recycled content. Its vapor permeability is higher and its R-value lower than XPS insulation. EPS insulation is classified by type: Type I is lowest in density and strength and Type X is highest. strips, 1x3s, and the upgrade from 2x4 to 2x6 batts. That seems like nothing compared to the additional complication and expense of including an inches deep layer of insulation on all exterior walls."
Our expert's opinion
Here's what GBA technical director Peter Yost thinks:
There's lots of good analysis and advice built into this Spotlight. I agree with Dana Dorsett that BEopt modeling can provide good guidance and useful sensitivity analysis around the key elements that Farm House is considering.
For my money — and based in no small part on the work that Building Science Corporation has done for high-performance design in Climate Zone 3 — here are the three most important design considerations for homes aiming for energy efficiency, indoor air quality, and thermal comfort:
Airtightness. Even without much information on the actual design, in my experience the continuity of the building enclosure air control layer is easiest to do on the exterior. You certainly can get this in many ways, but the Zip wall system is a good option. Another advantage of this approach is that a continuous exterior air barrierBuilding assembly components that work as a system to restrict air flow through the building envelope. Air barriers may or may not act as a vapor barrier. The air barrier can be on the exterior, the interior of the assembly, or both. protects from wind-washing at corners.
Better windows and solar shading. BEopt would certainly show this, but windows tuned by location and aspect and properly shaded give a big performance boost in Climate Zone 3. In a recent analysis I did using Climate Consultant 6, exterior shading of windows and doors alone pulled around 25% of annual hours into the ASHRAE 55 thermal comfort parameters.
HVAC. All ducts and equipment should be inside the conditioned spaceInsulated, air-sealed part of a building that is actively heated and/or cooled for occupant comfort. , and the systems should be designed using ACCA Manuals J, S, and D. This was not mentioned in the Q&A exchanges, and it’s critical to high performance (energy efficiency, IAQIndoor air quality. Healthfulness of an interior environment; IAQ is affected by such factors as moisture and mold, emissions of volatile organic compounds from paints and finishes, formaldehyde emissions from cabinets, and ventilation effectiveness., and thermal comfort). Achieving a high-performance HVAC system is easy if it is identified as a driver of design and if you have an HVAC contractor who can deliver the design.
Tags: , ,
Image Credits:
  1. Huber Engineered Woods
1.
May 29, 2017 3:23 PM ET
I agree with Martin
by Alan B
If the OP wants to be adversarial then whats the point, as long as the OP meets minimum code anything else above it, good or bad is on the OP, not us
2.
May 29, 2017 4:48 PM ET
hmmm...to me, the OP did not
by c l
hmmm...to me, the OP did not seem at all adversarial, just trying to figure this out, as am I.
The chart indicates the biggest bump you get is by going from 2x4 to 2x6, presumably to get the extra 2" of insulation. The bumps after that are more incremental. Do the referenced framing percentages roughly correlate with 16" vs 24" on center?
If so, the 2x6 at 24" oc is the closest to the Bonfiglioli wall. Does the Bonfiglioli wall in the chart represent a 2x4 wall at 16" oc with the strips added to make it 2x6?
Also, does it matter what you fill the wall with? ie the chart assumes stud cavities filled with (fiberglass?) batts. Does filling a 2x6 @ 24" oc with dense pack cellulose still make that wall 5% less efficient than filling a 2x4 @ 16" oc Bonifiglioli (same depth as 2x6) with dense pack cellulose?
It would also be interesting to understand the cost differences among the various walls. I learned a 2x4 @ 16" oc with ZipR is 10% more expensive than a 2x6 @ 24" oc with regular Zip. The second wall also has a higher effective R value...better wall, less money.
The closing comments attributed to Dana are reassuring. If you are already focused on all a tight house, windows/shading and HVAC, maybe this wall type exercise has less impact...
I'd love to see a similar article about nailbase vs. extra insulation insulation in attic vs cost of both.
3.
May 29, 2017 5:28 PM ET
Answers for c l (#2)
by Dana Dorsett
"Do the referenced framing percentages roughly correlate with 16" vs 24" on center?"
Yes (roughly) but it varies.. Going all out with Advanced Framing on the framing package could get it down to ~15%.
"Does the Bonfiglioli wall in the chart represent a 2x4 wall at 16" oc with the strips added to make it 2x6?"
I would presume that to be the case- 16" o.c., with 25% framing fraction, since 2x4 framing usually won't meet structural requirements at 24" o.c.
"Also, does it matter what you fill the wall with?"
Basically no, as long as it's air tight and installed to the best standards it's all about the same. Going from R4.2/inch rock wool to R3.7/inch fiberglass is only a few percent hit, going from R3.7/inch fiberglass to R3.7/inch dense packed cellulose has effectively zero change (except for extremely modest thermal mass benefits from the dense cellulose.)
"The closing comments attributed to Dana are reassuring."
That was all Peter Yost commenting, not me (although we do agree.) Looking at the wall assembly performance in isolation, without considering the other factors isn't usually going to provide the optimal price/performance value for the house as a whole. Peter's comments specifying window types & sizes based on direction and shading can be a really CHEAP performance enhancement for any house, but particularly true in zone 3, where heating & cooling degree-days are roughly equivalent. Those improvements are pretty easy to tease out of BeOpt simulations with a bit of focus, and no amount of wall-R is going to compensate for ignoring the effects of window type, size, & orientation.
"I'd love to see a similar article about nailbase vs. extra insulation insulation in attic vs cost of both."
That's easy (without putting numbers on it): R75 on the attic floor is SUBSTANTIALLY cheaper than even R38 at the roof deck (whether nailbase or not) , even when it means custom plenum trusses to accommodate the ducts & air handler below the insulation layer and to manage the deeper insulation depth & weight.
http://www.greenbuildingadvisor.com/blogs/dept/building-science/use-plen...
4.
May 30, 2017 8:30 AM ET
I wish the OP had mentioned where in CZ3 he lived
by John Clark
because in my opinion living on the northern edge CZ3 is a much different climate than the southern edge below the humid-warm line.
I do think Dana was on to something with the addition of a PV array and better air sealing. I know my own state (Georgia CZ3) has focused on ratcheting down air sealing requirements while leaving wall thickness (2x4) unchanged.
5.
May 30, 2017 9:51 AM ET
I did
by Clay Whitenack
I am putting the finishing touches on a home we built in the central KY, which is CZ4A. We went with exterior insulation and tons of cellulose in the attic. It was probably overkill. However, I don't regret it. My HVAC loads are almost nothing compared to other houses this size, and all that extra insulation is going to make it that much easier to get to net-zero when I start working on the solar projects.
6.
May 30, 2017 3:16 PM ET
It is good to be reminded
by Gordon Franke
It is good to be reminded that air sealing, windows, and HVAC may be as or more important than wall insulation levels. As a novice GBA reader interested in going at least in the direction of Passive House it is easy to become fixated on the desirability of an exterior layer of insulation. However, the prospect is daunting when you actually get down to it. Do I need to contact the architect for updated plans? If I don't will the contractor know how to adjust the roof overhangs so that they still look right with the extra wall thickness? Can I convince the contractor to learn how to do this installation, especially with an uncommon material such as Roxul boards? Will the workers be able to get the window details and flashing correct? Will they be able to create a flat surface for the siding? How can I convince my spouse of the value of going through all of this trouble? Do I have enough money to pay for all of this extra material and labor?
With the Bonfiglione wall you can achieve a similarly high wall R-value and use the money you save to buy better windows, HVAC, air sealing etc.
The main thing you miss out on as far as I can tell is warm sheathing. With the Bonfiglione wall your sheathing will be cold. Plus the rooms will shrink a bit.
Also, I would like to avoid foam if possible due to its fire-enhancing, possible off-gassing, and vapor impermeable properties. The Bonfiglione wall puts the foam only where its structural properties are useful. It is as if you have a Roxul layer with EPS stripes embedded in it. MUCH easier than trying to create a structural connection through Roxul board. And the wall as a whole remains vapor permeable unlike with a solid foam layer.
7.
May 30, 2017 3:19 PM ET
Response to C L
by Gordon Franke
In the chart, the bars aren't necessarily in order of expense or complication, and the later bars are not the result of adding things to the earlier ones, so I'm not sure it makes sense to say the biggest bump is going from 2x4 to 2x6 and the rest are incremental. It would be equally valid to say the biggest benefit to be had is going from 2x4 to the Bonfiglione wall (of the options considered).
I used 25% as the percentage of framing for the 2x4 calculations including the Bonfiglione wall. In new construction there are more comparisons to be made between 2x4 and 2x6 walls with different o.c. measurements and interior vs exterior insulation layers etc. Since I'm renovating my main interest was 2x4 with exterior insulation vs 2x4 furred out to 2x6 Bonfiglione-style.
8.
May 30, 2017 11:17 PM ET
Edited May 30, 2017 11:18 PM ET.
I am the OP
by Farm House
Air sealing is where I have always planned to hit it the hardest. Zip Exterior, Dense packed Fiberglass or cellulose between 2x6 studs. Gaskets installed beneath plates, spray foaming the roof line , rim joists, etc...... and if that weren't enough, I plan to spray an elastomeric caulk into all the joints at 1750 psi. I'm sure it's overkill, but I only get one shot.
I'm buying the best windows and doors that I can afford (wood with aluminum cladding). About 2/3rds of the windows are covered with a 10' deep porch roof line or face North/North East and will receive very little direct sunlight. Wouldn't be a farmhouse without lots of wrap around porches.
The house will be near Greenville, SC.
9.
Jun 1, 2017 8:00 AM ET
@OP
by John Clark
Here's a good link for figuring out your heating/cooling loads.
http://www.phius.org/phius-2015-new-passive-building-standard-summary
Drill down on the map to upstate SC. Watch out for the big peach!
Become a GBA PRO!
