Efficient supply layouts
Home-run Layouts from a Manifold Can Reduce Waiting Time for Hot Water
Read the full article by subscribing to GBA Pro for valuable how-to information and insights about
Efficient supply layouts, including:
  • Design and build strategies
  • Necessary codes
  • Application how-tos
  • Using materials
Diameter of the line, distance and speed the water travels affect heat loss
Manifolds are like main electric panels. In a manifold system (also called a "home-run" system), the hot water and cold water supply lines feed a manifold that distributes hot and cold water to each fixture in the house. Each fixture gets a dedicated run of tubing from the manifold.
Manifolds have separate chambers for hot and cold water. The cold-water chamber is fed from the main water supply line and the hot-water chamber is fed from the ...
Tags:
