Flanged Window Replacement in a House with Wood Siding (2/5)
Step 2: Remove The Old Window
See how to build window casing and use that casing as a template to cut back existing siding before you install the new window
With Bill Robinson
Read the full article by subscribing to GBA Pro for valuable how-to information and insights about
Flanged Window Replacement in a House with Wood Siding (2/5), including:
- Design and build strategies
- Necessary codes
- Application how-tos
- Using materials
