Heating Options
Green Heating Systems Can Heat the House and Its Water
Solar heating
Solar heat is the greenest choice.
Well designed active solar space heating systems are expensive and rare. Their main disadvantage is the high cost of the required equipment.
Heat Pumps
Heat pumps use electricity but they don’t directly burn any fuel to generate heat. Instead, they collect heat from the air, from pond or well water, or from a liquid medium circulated through pipes in the earth or a pond. The electricity is used for pumping the liquid and operating a compressor. Heat pumps can provide both heating and air conditioning, and they also can be used to provide domestic hot water.
Boilers
Modern boilers are very efficient. Boilers can burn natural gas, propane, fuel oil, or biomassOrganic waste that can be converted to usable forms of energy such as heat or electricity, or crops grown specifically for that purpose. to supply hydronic heating and domestic hot water systems. Electric boilers also are available.
Furnaces
Hot air furnaces can provide heat and ventilation but not hot water. Hot air furnaces can burn natural gas, propane, fuel oil, or biomassOrganic waste that can be converted to usable forms of energy such as heat or electricity, or crops grown specifically for that purpose. , and they can also use electricity. The minimum AFUEAnnual Fuel Utilization Efficiency. Widely-used measure of the fuel efficiency of a heating system that accounts for start-up, cool-down, and other operating losses that occur during real-life operation. AFUE is always lower than combustion efficiency. Furnaces sold in the United States must have a minimum AFUE of 78%. High ratings indicate more efficient equipment. for a fossil-fueled noncondensing furnace is 78% but condensing furnaces fired by natural gas with efficiencies of 95% or more also are available.
DIVE DEEPER
OTHER CONSIDERATIONS
think of the building itself
The most effective way to cut heating costs is to make the house as efficient as possible:
Orient the house to take advantage of the sun
Build a tight and well insulated home
Choose energy-efficient windows
FUEL VARIES BY REGION
Choice is unavoidably risky
Natural gas may be cheap and plentiful in some parts of the country, for example, but unavailable in others. Fuel oil is a common heating fuel in New England and the upper Midwest, but hardly used at all in many other parts of the country.
Solar is a good long-term bet. Market gyrations change the price of some fuels much faster than others, and retail prices for fossil fuels can go up and down like a roller coaster due to weather, political upheavals, speculation, availability, or just market whim. Making decisions about what kind of heating equipment to use for the next 20 years carries unavoidable risk. Active solar systems are the only option where long-term costs are completely predictable.
IS AN ALL-ELECTRIC HOUSE THE ANSWER?
Keep the house small and tight
Most zero-energy home designers aim for an all-electric house; ideally, the electricity drawn from the grid is balanced annually by the electricity fed back to the grid by a home's photovoltaic(PV) Generation of electricity directly from sunlight. A photovoltaic cell has no moving parts; electrons are energized by sunlight and result in current flow. array or wind turbine. (However, some zero-energy home designers permit the use of natural gas appliances.)
Successful near-zero-energy homes have been built using electric-resistance baseboard heat, ground-source heat pumps, and air-source heat pumps. In all cases, the key to success is to keep the house small and to build a shell that is extremely well insulated and tight.
The U.S. Department of Energy notes that most electricity is produced in plants running on oil, gas, or coal that are only about 30% efficient. And transmission losses are roughly another 10%.
The cost of electricity to residential customers varies widely around the United States, from less than $.07 per kilowatt hour (kWh) in some parts of the Pacific Northwest to more than $.23/kWh in Hawaii. The national average for the first three months of 2008 was about $.10/kWh. At the lower end of the range, electricity can be very competitive with other energy sources, and may in fact prove more economical than heating with fossil fuels.
Because the cost of electricity is regulated, it tends to rise more slowly than some other fuel options. Whether it makes sense to switch to electricity as a heat source depends on a variety of factors other than cost alone, including the type and efficiency of the heating appliance.
MASONRY HEATERS
Clean but expensive
A masonry heater is a special kind of fireplace designed to store the heat produced by very hot intermittent wood fires. In order to store heat, a masonry heater requires a lot of thermal massHeavy, high-heat-capacity material that can absorb and store a significant amount of heat; used in passive solar heating to keep the house warm at night. . Masonry heaters have been used for centuries to heat homes in Germany, Austria, Scandinavia, Ukraine, and Russia.
Masonry heaters have several advantages:
  • Because they require a very hot fire, they burn wood efficiently.
  • They are mechanically simply and very durable.
  • Once hot, they can keep a house warm for 24 hours.
  • They also have disadvantages:
  • Because masonry heaters are massive and are usually site-built, they are expensive. It is not unusual for a masonry heater to cost $15,000 to $30,000.
  • In cold weather, owners of masonry heaters must kindle a fire from scratch every 24 hours. This chore is avoided by owners of woodstoves, since woodstoves hold coals longer than masonry heaters.
  • Once lit, a masonry heater continues to radiate heat for hours, and cannot be "dialed back" in response to changes in the weather. If the sun comes out in the middle of the day, a home with a masonry heater can easily overheat.
  • DO THIS FIRST
    It's best to invest in the shell
    If a house is small and built with a tight, well insulated shell, its heating needs will be very modest. With a very low heating demand, any heating system will be cheaper to run and pollute less.
    When you're building a new home, tighten the shell and improve the insulation so you can get a small heating system. When retrofitting a new system into an old house, spend money first on air sealing, insulation, and better windows. You'll offset some of the cost by buying a smaller system.
    GREEN POINTS
    LEEDLeadership in Energy and Environmental Design. LEED for Homes is the residential green building program from the United States Green Building Council (USGBC). While this program is primarily designed for and applicable to new home projects, major gut rehabs can qualify. A brief overview of the points structure: - Certified: 45 – 59 points - Silver: 60 – 74 points - Gold: 75 – 89 points - Platinum: 90 – 136 points Total available points: 136 Total prerequisite points: 25 -H See individual systems for points related to efficiencies.
    NGBSNational Green Building Standard Based on the NAHB Model Green Home Building Guidelines and passed through ANSI. This standard can be applied to both new homes, remodeling projects, and additions. NGBS Under Ch. 7 — Energy Efficiency: up to 17 pts. for HVAC(Heating, ventilation, and air conditioning). Collectively, the mechanical systems that heat, ventilate, and cool a building. system efficiency (703.4); 5 pts. for 3rd-party HVAC testing (704.6).
    ABOUT HEAT AND HOT WATER
    Most houses need equipment to stay warm
    When the sun is shining, a passive solar house design can take advantage of available solar heat. But in many climates, winter days are short and winter weather is often cloudy, so passive solar gains are rarely adequate to keep a home warm all winter long.
    A heating system strongly influences a home's energy use. Only three things have a greater effect: air sealing, insulation, windows.
    ABOUT HEATING FUEL CHOICES
    Consuming less is more important than the type
    All forms of space heating have environmental as well as financial implications, so there’s no such thing as cheap heat. The main choices are natural gas, propane, electricity, fuel oil, wood or wood pellets, and solar.
    Solar
    A passive solar house utilizes the sun's heat without mechanical devices. Good passive solar design, which should include attention to producing a tight, well-insulated building envelopeExterior components of a house that provide protection from colder (and warmer) outdoor temperatures and precipitation; includes the house foundation, framed exterior walls, roof or ceiling, and insulation, and air sealing materials., is the best way to minimize energy consumption. Most passive solar houses need a supplemental heating system, which can use one or a combination of several fuels.
    A solar hot water system can cut energy bills for heating domestic hot water in half. Unfortunately the case for active solar space heating isn’t as compelling. Systems large enough to heat a house are complex and expensive. An inherent problem is that when the need for heat is at its peak the days are short, winter weather is often cloudy, and the sun is at its lowest point in the sky. In northern climates, it is quite difficult to design an active solar heating system capable of meeting a significant portion of winter heating loads.
    Wood
    In the right circumstances, firewood harvesting can be done sustainably. Since the carbon released into the atmosphere when firewood is burned is balanced by the carbon pulled from the atmosphere when trees are grown, burning wood is (arguably) carbon-neutral.
    Although they aren’t practical everywhere or for all homeowners, high-efficiency biomassOrganic waste that can be converted to usable forms of energy such as heat or electricity, or crops grown specifically for that purpose. appliances may be the least expensive form of heat where the fuel is readily available. Even at prices approaching $200 per cord (a cord equals 128 cu. ft.), a wood-fired boiler or furnace is generally cheaper to operate than an appliance that burns oil, natural gas, propane, or electricity. Unless a homeowner is willing to undertake annual chimney-cleaning chores, any calculation of the cost of burning firewood should include the cost to hire a professional chimney cleaner every year.
    Pellet stoves
    These burn small, cylindrical pieces of compressed wood chips or sawdust. Stove manufacturers claim efficiencies of up to 87%, making these appliances as efficient as some of the best oil-fired boilers. Pellets are easier and neater to handle than cordwood, and electrically driven augers load fireboxes automatically. These appliances produce relatively little ash.
    Corn stoves
    These burn corn kernels and are similar to pellet stoves. In rural areas, the price of corn occasionally drops low enough to make it economical to burn corn. However, in light of the recent global increases in food prices and food shortages in many countries, burning edible crops for fuel remains controversial.
    Natural gas is clean-burning and less expensive than some alternatives. Most of the natural gas used in the United States is produced domestically. Canada contributes the bulk of the remaining 16%, although a growing volume of gas is being imported from abroad in the form of liquefied natural gas (LNG).
    Natural gas is used to run 60% of the heating equipment installed in new single-family homes. Like any fossil fuel, natural gas releases carbon dioxide into the atmosphere when its burned. But gas is cleaner than other petroleum products because it emits less sulfur, carbon, and nitrogen when it is burned. It produces almost no ash. In rural areas beyond the reach of natural gas pipelines, many homes are heated by propane. But propane always costs significantly more than natural gas.
    Electricity is an expensive fuel in most areas of the country, although recent price increases for gas and oil have made electricity a bargain in a few areas.
    Fuel oil is often the first choice of fuel for homes that are located beyond the reach of natural gas pipelines. The U.S. Census Bureau reports that fuel oil was the source of heat in only 1% of new single-family houses completed in 2005. It’s more common in New England and the upper Midwest where oil boilers and furnaces are installed in 15% of new houses.
    There are two drawbacks to fuel oil: price volatility and fuel efficiencies that have lagged behind those of gas-fired appliances.
    ABOUT WATER HEATING
    Reduce consumption and heat water efficiently
    Heating water accounts for about 17% of the average home’s energy budget. Focusing on efficiently heating the water, installing low-flow fixtures, using the shortest supply lines possible, keeping pipes insulated, choosing an efficient clothes washer, and capturing heat from waste water will save energy dollars.
    Water heaters use a lot of energy, regardless of whether they're powered by natural gas, propane, electricity, or fuel oil. Bathrooms with multiple showerheads and huge bathtubs or hot tubs practically guarantee high energy bills. The object is to make sure that as little energy as possible is wasted, by choosing an efficient water heater and reducing consumption.
    Tank-style heaters combine a heat source and an insulated storage tank. Water is typically heated either by a gas flame or by electric elements inside the tank. Once water is brought up to temperature it sits in the tank until it’s needed. Water is reheated as necessary.
    Tankless heaters heat water only on demand. When someone turns on a hot water tap, a gas or electric heating element is triggered. Water is heated only as long as the tap is open. This can save energy, but not water.
    Indirect heaters have no energy source of their own. Instead, they rely on a heat-exchange loop connected to a hot-water boiler. Hot water inside the boiler is piped to a coil immersed in the tank, bringing stored water up to temperature.
    Solar collectors look increasingly attractive as the cost of fossil fuels continues to rise. There are several types of solar hot water systems on the market that are capable of providing about half of the typical household’s hot water supply.
    Heat-pump water heaters are available as stand-alone water heaters or as part of a space-heating system (ground-source heat pumpHome heating and cooling system that relies on the mass of the earth as the heat source and heat sink. Temperatures underground are relatively constant. Using a ground-source heat pump, heat from fluid circulated through an underground loop is transferred to and/or from the home through a heat exchanger. The energy performance of ground-source heat pumps is usually better than that of air-source heat pumps; ground-source heat pumps also perform better over a wider range of above-ground temperatures.). These units can be two or three times as energy efficient as a conventional electric tank-style heater.
    FOR MORE ABOUT HEATING DOMESTIC WATER
    FURTHER RESOURCES
    BuildingGreen.com:
    Fuel cost calculator
    BuildingScience.com:
    Combo Space/Water Heating Systems—"Duo Diligence"
    Heating Choices
    Masonry heaters:
    Masonry Heater Association of North America
    Image Credits:
    1. Fine Homebuilding
    2. John Hartman / Fine Homebuilding
    Tags: , , , , , , , , , , , , , , ,
    Post new comment
    The content of this field is kept private and will not be shown publicly.
    Discussion policy: The editorial staff at GreenBuildingAdvisor.com does review user submissions. Please be respectful of others. Inappropriate content will be removed.
    • Web page addresses and e-mail addresses turn into links automatically.
    • Allowed HTML tags: <a> <em> <strong> <cite> <code> <ul> <ol> <li> <dl> <dt> <dd> <blockquote>
    • Lines and paragraphs break automatically.
    * required fields
