Video: How to Hang Airtight Drywall (1 of 3)
Myron Ferguson shows how drywall can make your house more energy efficient when installed with caulk, canned foam, gaskets, and airtight electrical boxes
Watch the video
Produced by Colin Russell and Daniel Morrison
Justin: Stopping air leaks is the single most important part of making a house more energy efficient. You can stop air on the outside with plywood, housewrap, and tape, but the best air barrierBuilding assembly components that work as a system to restrict air flow through the building envelope. Air barriers may or may not act as a vapor barrier. The air barrier can be on the exterior, the interior of the assembly, or both. is more of a system that incorporates all the components of a wall or roof assembly.
We decided to drywall the garage shop in Fine Homebuilding’s project house using the Airtight Drywall Approach. Partly to show our readers how to do it and partly so that we could make Myron Ferguson do our dirty work for us.
The outside of the house will eventually be covered with housewrap and foam sheathingMaterial, usually plywood or oriented strand board (OSB), but sometimes wooden boards, installed on the exterior of wall studs, rafters, or roof trusses; siding or roofing installed on the sheathing—sometimes over strapping to create a rainscreen. , so the drywall is not the primary air barrier; it is part of a larger system.
Myron: When it comes to materials, drywall is going to be our chief component in making the interior of this wall and these ceilings airtight. Drywall makes a nice air barrier because it's a relatively solid piece of material. The only place you have potential air leaks is through little openings or along seams or inside corners. I'm comparing this to, say, a knotty pine tongue-and-groove ceiling. Now that's not an air barrier at all. It's just full of holes. So drywall to start out with is going to be a very good air barrier.
Justin: The other main materials Myron uses in this project are pretty common on most job sites: construction adhesive, latex caulk, and canned foam. Some other materials are a little less common on job sites: mainly foam boxes for sealing electrical outlets.
Myron: A good practice for any drywall job, regardless of whether you are going to do airtight drywall, is to walk through with a building contractor a few prior to the delivery of the drywall. That way you you can identify any potential problems and all that can be corrected before you actually do any drywall work.
Justin: This garage has a 2x6 bottom plate, but 2x4 studs. Before Myron came out, we placed blocks in each stud cavity because without blocks to glue the bottom of the drywall sheets to, a considerable amount of air could flow through the wall assembly.
If not already done at the pre-construction walk-through, seal all of the gaps between framing members.
Around windows, around doors, and at the gaps between king stud and trimmer, between header and top plateIn wood-frame construction, the framing member that forms the top of a wall. In advanced framing, a single top plate is often used in place of the more typical double top plate., and between the double – or, in this case, triple – top plates.
Myron: If the gap is wider than 1/4 inch, it's a good idea to use spray foam instead of the caulking. It's important to use flexible caulk, because you don't want to use a caulk that will dry out and shrink, or maybe not even stretch and move should the structure expand and contract, because we don't want these gaps to open up. Then there would be a passage for the air. We've done all the air sealing that we can at this point, so we'll start to hang the drywall. We're going to start with the ceiling.
If you are a GBAGreenBuildingAdvisor.com Pro member, click here to see episode 2: Video: How to Hang Airtight Drywall (2 of 3).
Tags: , , , ,
3.
Sat, 04/13/2013 - 14:55
Toxic construction materials
by Jason Peacock
I'm very aware of this. I think that common residential construction is a comedy of errors. There is so much room for improvement. I wish that fiberglass batts were illegal and that you had to have a certification, similar to Lead Paint, to work with them. We've got so many toxic construction materials that a majority of homes are built toxic, without a lot of thought put into it. Things are changing but ever so slowly and unfortunately cost wins out a majority of the time. You get what you pay for.
2.
Sat, 04/13/2013 - 13:53
Response to Jason Peacock
Jason,
Fiberglass batts are the most common residential insulation material in the country -- by a long shot.
1.
Sat, 04/13/2013 - 13:38
Fiberglass
by Jason Peacock
People still use fiberglass?
