Several years ago, I heard something really interesting at a talk by a self-described futurist. “Futurists,” she said, “look at weak signals and try to figure out which ones will become strong signals.” I hadn’t thought much about what futurists do before that, but it made perfect sense. So let me apply that to the field of building science and explore some of the issues we’ve been talking about at Energy Vanguard over the past year. Not all of these are weak signals, but they’re all things that do seem to be growing in strength.
Indoor environmental quality
“Indoor environmental quality” is a term that applies to several factors that affect the health and well-being of the people who dwell in homes, offices, schools, and other buildings. The diagram below shows the six most commonly included qualities. Sadly, only one seems to be gaining traction: indoor air quality (IAQ).
Indoor air quality. Two things have driven the increased interest in IAQ: the COVID-19 pandemic and wildfires. People want better indoor air, and they’re asking for whole-house ventilation and better filtration.
This is great! We know how to deliver these things. We know a heck of a lot about different indoor air pollutants and how to deal with them. Ventilation and filtration are two of the six primary methods to achieve good IAQ. The others are source control, moisture control, airtightness, and pressure balancing.
Thermal comfort is sorely lacking in a great many buildings, and so are attention to the other factors of indoor environmental quality. Maybe next year we’ll get to elevate one or more of the others.
Building enclosures
Rooflines insulated without spray foam. I’m seeing more and more reports about insulating rooflines above the roof deck with rigid insulation products like mineral wool or foam board. Most homes still have unconditioned attics. But in the high-performance world, unconditioned buffer spaces are going away. Well, except for the attached garage.
I’ve even seen a new term recently for a house with rigid insulation on top of the roof deck: monopoly framing. The basic idea is that the roof rafters end at the walls, allowing continuous exterior insulation over that critical transition. Seattle home builder—and one of our clients—Sean Conta explained the details in an article on Green Building Advisor.
High-performance air-sealing and flashing tapes. There are many products for air sealing, but two of the big names here are Siga and Pro Clima. I got to use some of the Siga products in my basement renovation, and they’re amazing. See the article and video I did about Siga’s special corner flashing tape for windows. As airtightness requirements keep improving, products like these are becoming more important.
Mechanical systems
Makeup air. We’ve been doing a lot more makeup air systems in our designs lately. Airtight houses and oversized range hoods are the main reason, but sometimes it’s just because of an airtight house. Read my article on makeup air for more info.
Dehumidification. As building codes require more insulation and greater airtightness, moisture problems are becoming more common. Increasing the potential for moisture problems is the fact that air conditioners have had to meet much higher efficiency requirements. That increases the problem, because more-efficient air conditioners don’t dehumidify as well as the old ones. (In fact, I heard one person jokingly say that the solution to humidity problems is to go back to SEER 10 air conditioners.) Anyway, these two trends have brought dehumidifiers into the spotlight. We specify a lot of them in our HVAC design jobs.
Dirty ductless units. Ductless minisplit heat pumps have gotten a lot of attention recently. They don’t filter well, and the blower wheel gets very cold. See the article and video I did when we cleaned my ductless unit last summer.
Air-to-water heat pumps. When you see the term “heat pump,” it almost always refers to an air-to-air heat pump. That is, in winter it picks up heat from the outdoor air and transfers it to the indoor air. The indoor part (the air handler) distributes the warm air through ducts. An air-to-water heat pump still pulls heat from the outdoor air, but it then puts that heat into water to distribute throughout the house. A huge advantage of these systems is that they’re package units. That means all the refrigerant is contained in the outdoor part of the system. The installer doesn’t have to connect refrigerant lines. There’s no refrigerant flowing through the house. And there’s less refrigerant. I think the refrigerant transition that’s happening now as well as climate concerns may drive more demand for these systems.
Refrigerant transition. New regulations are coming in that require us to move away from the current generation of refrigerants for air conditioners, heat pumps, and other mechanical systems. We’ve made great strides in getting rid of the refrigerants that destroy the ozone layer. Now we’re going to refrigerants with lower global warming potential. This will have some large ramifications, and we’re already having to deal with it in our HVAC design business here at Energy Vanguard.
Getting ducts into conditioned space. We’ve known for a long time that putting ducts in unconditioned attics, crawlspaces, and garages isn’t very smart. Most of our HVAC design clients are doing custom homes, and they’re mostly getting the ducts into the conditioned space one way or another.
Rheia duct system. This one is a spinoff from the previous topic. We’ve been getting more and more requests for the Rheia duct system from our HVAC design clients. We’ve had some talks with Rheia, and one of our designers, Alex DeSpain, is in the process of replacing his ducts with the Rheia system. I’ll have more to say about that after he has it installed and gets direct experience with it.
Plumbing and air sealing
Smaller pipes for faster hot water. Maybe this is just because I’ve been so into this topic over the last few years. I reduced my wait times for hot water with a retrofit of three fixtures back in 2022. Then last year I expanded and improved my retrofit to include the basement as part of our basement renovation. I’ve done a bunch of things to the places my wife and I have lived over the past 15 years. This is the one change I’ve made that my wife loved!
As I write this, Gary Klein is staying with me for a couple of days. He’s here to talk about hot water at the Atlanta BS & Beer meeting later today. Tomorrow, we’re going to shoot some video. Stay tuned to our YouTube channel.
Ultrasonic airtightness testing. The blower door has ruled this realm since it was invented back in the 1970s, but that could change some day. I first heard about using ultrasonic sound waves to find air leakage a few years ago. It seemed a bit out there to me, and I forgot about it. In the past month, though, I’ve heard about it from two different sources. See the article by Randy Williams at Green Building Advisor to learn more about this.
What’s missing?
I haven’t mentioned electrification, and that’s definitely a biggie. I think it’s going to keep rolling, but we’ll figure out how to incorporate it better. One easy way to take advantage of heat pumps in existing homes is to pair them with a furnace. I wrote about these dual-fuel systems a while back, and they can help us get their quicker.
Similarly, I glossed over heat-pump water heaters and induction cooktops. What else have I missed?
One thing that wasn’t missing for my New Year celebration, though, was Possum Drop. It’s a local party I’ve been attending since 2006, and it was another spectacular year. The possum dropped at midnight, and all is well. OK, maybe not “all,” but at least the hosts’ house once again remained standing next to the ashes of the giant possum. (No, it’s not a real possum, and no possums were hurt.)
Happy New Year!
Allison A. Bailes III, PhD is a speaker, writer, building science consultant, and the founder of Energy Vanguard in Decatur, Georgia. He has a doctorate in physics and is the author of a bestselling book on building science. He also writes the Energy Vanguard Blog. For more updates, you can follow Allison on LinkedIn and subscribe to Energy Vanguard’s weekly newsletter and YouTube channel.
