Building Science
Reading the Roof for Heat Loss
Learn how to read a roof after a snowstorm.
The north-facing roof of my house with a lot of snow remaining two days after the storm
Do you know how to read a roof after a snowstorm? When you do, it tells you something about how good the building enclosure is. We had that opportunity here in Atlanta last weekend. We got 2 in. to 3 in. of snow last Friday, and it stuck around for a bit. On Sunday, I went for a walk around the area where I live. It had been mostly at or below freezing on Friday and Saturday. Then the sun came out, and it warmed up on Sunday. So I went out to read the roofs and take some photos.
Before we get started, the basic idea here is to understand heat flow from the conditioned space below the roof up to the roof and the snow on it. That heat can come from poor insulation, air leakage, duct leakage, or poorly insulated ducts.
Ready? Let’s start with the video.
Ambient temperature and sunshine
One of the first things to scope out is which direction the roof faces. The lead photo above is the north-facing side of my roof. Notice all the snow there.  The photo below shows the south-facing side. On the day I took these photos, it had been sunny all day. The temperature was above freezing from about 11 am until 7 pm that day, with a high of 43°F (6°C).
The south-facing side of my roof has no snow.
And that’s why the front, south-facing side had no snow on it. All of the snow on the ground in the front yard had melted too. It wasn’t heat from inside the house that melted the snow on the south side. It was above-freezing temperatures and sunshine.
A range of snow-melt patterns
Now let’s look at some photos of other houses nearby. In all of them, I’m looking at the north side of the house.
Another north-facing roof with much of the snow melted
A north-facing roof with much of the snow melted
The first one (above) has a bit of snow left on the upper roof. The middle part had lost all its snow. Perhaps there’s a furnace or ductwork in that area? That could give off enough heat to melt snow in that type of pattern. And that would be in addition to the heat getting into the attic from air leakage and lack of insulation. Without going into the attic, it’s hard to pinpoint the exact source of heat.
On the lower left roof, there’s a lot of snow. But that roof is over the carport, so there’s no source of heat below to melt the snow.
A complex roof with a lot of the snow gone
Ah, dormers! They’re notoriously difficult to insulate and air seal properly. With four dormers on the house above, a lot of heat loss happens there. There are also some vaulted ceilings inside, and those also are rarely insulated and sealed well. Complex roofs usually have a lot of heat loss.
An interesting pattern of melted snow
This one is similar to the first one: There’s a garage on the left with lots of snow, and some snow on the roof with a V-shaped pattern. The snow over the front door is still there for the same reason there’s snow on the roof over the garage— there’s no heat source below.
One thing that stands out in the photo above is the pattern of roof rafters. Wood has a bit of thermal resistance, so the snow lasts longer right above the rafters.
More heat loss through the roof
This one has an interesting mix of areas with snow and a lot of melted areas. Notice that there’s no snow right around the skylight over the front door.
The four houses above are typical for heat loss to the roof. The air leakage, poor insulation, and duct leakage put enough heat at the roof deck to melt most of the snow—but not all of it. So we know there’s been some attempt to reduce heat flow to the roof.
A really bad one
Here we have a classic. It looks like this house has no insulation at all and probably a fair amount of air leakage. If it were just air leakage, there’d likely be more snow down lower. Since warm air rises (the stack effect), heated air leaking into the attic would affect the upper parts of the roof more than the lower parts.
A perfect example a house that spends too much money on heat
A perfect example of a house that needs attention
The only snow left on this roof is over the unconditioned spaces: the carport on the left and the overhangs at the perimeter.
And a couple more good ones
It turns out that my house isn’t the only one around here that does a good job controlling heat flow at the top of the house. Let’s take a look at two others.
Hey! Look at all that snow on the roof!
I know exactly why this house has so much snow on the roof. It’s the house my wife grew up in. Back in early 2009, I did a lot of work in the attic to air seal and insulate it for her mother and stepfather. And you can see the effects sixteen years later!
Air leakage site in an unconditioned attic. This hole was cut to be a vent for the heat from the refrigerator.
Air-leakage site in an unconditioned attic. This hole was cut to be a vent for the heat from the refrigerator.
If I hadn’t fixed that house, it would look a lot like the others. It has a lot of can lights, and the insulation wasn’t great. But the biggest single source of heat to that attic before I came along was the refrigerator vent (above).
Another house that seems to retain heat
The house above is pretty good too. There’s definitely some heat loss going on here. You can tell because the rafter pattern is showing. But it’s better than most of the other houses around here.
A close reading of my roof
Now let’s dive into some of the snow-melt details on my roof. I’ve labeled three of the interesting areas in the photo below.
A closeup reading of the snow on my roof
1. Site of former furnace flue. We had our shingles replaced last year. I took advantage of that to have some of my unnecessary roof penetrations removed. A patch of shingles is showing here because that’s where the old furnace flue went through. I need to go up in the attic and get that part insulated again.
2. Bathroom exhaust-fan vents. There are two terminations for the bath fan ducts with a ring of shingles showing around them. Why? The open-cell spray foam in my attic wraps tightly around where they go through the roof. The problem, though, is that the ducts are metal. The attic is warm, and some of that heat gets carried away through the metal duct. Since we got our Zehnder energy recovery ventilator going, we’ve hardly used the bath fans, so it’s mostly conduction through the ducts.
3. Site of former plumbing stack. You may recall in my article about removing roof penetrations that I had two plumbing stacks removed from the eaves. This is where one of them was. I wasn’t able to get up there and re-insulate when they had it open, so we have some extra heat loss there.
Also, the other patches of snow melt along the eave are probably from the lack of spray-foam insulation above the exterior walls. When we had our soffits and fascias replaced in 2019, I ran around spraying foam in those places, but I wasn’t able to stay ahead of the work crew the whole time. I missed a few places, and it might have been where the snow is melted here.
Thermal imaging without an infrared camera
Snow and frost on the roof can help you find out how bad your home’s heat loss is. The more frost and snow, the better. But you have to understand all the reasons why the snow may have melted. Even on a perfectly insulated and air-sealed roof, snow can melt from exterior heat sources. If the temperatures are above freezing and the sun is shining, you have to look for the places that are protected from that heat. That’s why I looked at the north sides of the roofs. If I were in New Zealand, I’d look at the south sides.
What interesting snow-melt patterns and heat sources have you found?
Allison A. Bailes III, PhD, is a speaker, writer, building science consultant, and the founder of Energy Vanguard in Decatur, Georgia.  He has a doctorate in physics and is the author of a bestselling book on building science.  He also writes the Energy Vanguard Blog.  For more updates, you can follow Allison on LinkedIn and subscribe to Energy Vanguard’s weekly newsletter and YouTube channel.
5 Comments
  1. user-723121 | | #1
    With a very well insulated (and ventilated) attic, snow will lay uniformly on the roof. There will be no discernable variation in the snow cover, none. Does not matter the truss or ceiling type. Quality building or lack thereof becomes apparent with snow on roofs.
    Doug
    1. GBA Editor
      Allison A. Bailes III, PhD | | #2
      Doug: Yes, a well insulated attic is definitely a necessary condition for snow not melting on the roof. But insulation alone is not sufficient to keep indoor heat from reaching the roof and melting the snow. You also need an airtight building enclosure at the top to keep warm air from leaking into the attic or the roof assembly. And if you have that, attic ventilation isn't necessary.
  2. user-723121 | | #3
    Allison,
    My point is, an even snow cover is a sign of a well insulated and air sealed structure. In our cold MN climate, I am a firm believer in vented roofs. Has worked without fail in my home building experience. So much poor construction out there, attic venting may help with some of the moisture making its way into the attic. Accumulation and the melting of attic frost has been noted as a problem on the first warm day after a cold snap.
    Doug
    1. GBA Editor
      Allison A. Bailes III, PhD | | #4
      Doug: Kohta Ueno supports venting attics in cold climates. Here's what I wrote in an article questioning the need for attic ventilation:
      "Having said that, sometimes attic ventilation does help with moisture problems. Remember, cold air is dry air, so diluting the attic with outdoor air can dry it out. Engineer Kohta Ueno of Building Science Corporation says enough marginal cases are helped by venting that he wouldn’t recommend skipping it."
      You can see that article here:
      Is Venting an Unconditioned Attic Necessary?
      http://www.greenbuildingadvisor.com/article/is-venting-an-unconditioned-attic-necessary
  3. Piniuze | | #5
    I never thought about reading a roof after a snowstorm until I noticed my neighbor’s roof had completely melted while mine still had a thick layer of snow. Turns out, their attic insulation was practically nonexistent. It’s crazy how much heat can escape through a poorly sealed home. Before buying my place, I made sure to check reviews on KB Home https://kb-home.pissedconsumer.com/review.html to avoid any insulation nightmares. Now, after every snowfall, I look at roofs like a detective.
