BCP Green Builders project manager Ben Bogie explains how double-stud walls help meet the energy performance goals of this net-positive home being built in Upstate New York. He also talks about the attributes that make this his go-to assembly, including its familiar framing for carpenters, extra-deep insulation cavity, and inherent thermal break. We see ZIP System sheathing being installed and learn why it was used as the primary air barrier.
_________________________________________________________________________
Ben Bogie is a second-generation high-performance-building obsessive working as a project manager for BPC Green Builders of Wilton, CT.
4 Comments
Enjoying this series quite a lot. What made you all decide to go with Zip over something with more perms, like Plywood and adhered WRB?
I am also truly enjoying this series, and would like to learn more about the above question.
“[Deleted]”
So well done, great work everyone!
