Green Products and Materials
Hanging open web floor trusses on ICF walls after concrete pour
New residential construction, ICF lower level with open web floor trusses supporting the main floor above - I'm stuck in the middle of a "not my problem" battle between the…
Basement-to-Beautiful Insulation
Has anyone heard or have experience with a basement insulation system called "Basement-to-Beautiful?" I have a quote from a local contractor to furnish and install and trying to figure out…
Triple glazed window manufacturers
Good afternoon folks! I'm posting because I'm wondering about triple glazed window manufacturers that are worth getting a quote from. I've only gotten a quote from Logic so far for…
EIFS applied to Grace Ice & Water Shield (WRB)
If a Grace Ice and water shield WRB (with no water vapor permeability) has been applied to the face of the Plywood on a timber frame building, what EIFS detail…
How does Eastern White Cedar weather?
Good evening! I'm in the process of designing my first home, and I had been planning on using eastern white cedar shingles. Being from Massachusetts, I liked the idea of…
Spruce vs hemlock clapboards
Hello,Curious to hear what the long-time builders here think about spruce vs. hemlock clapboards. In my area primed spruce is nearly half the cost of primed hemlock. Assuming the clapboards…
