Detail Library
Building Plans for Insulated and Conditioned Crawlspaces
How to Seal A Crawlspace from Air and Water Leaks: Construction Details For a Mold-free, Energy-Efficient Crawlspace.
23 Encapsulated crawlspace details for a tighter, more energy-efficient , healthier, and more comfortable home
RADON RETROFIT
Section View: Radon Vent, Dirt FloorDOWNLOAD: PDF | DWG
FREE SAMPLE:
Wall Section-Radon, Sump, InsulationDOWNLOAD: PDF | DWG
FOUNDATION WATER MANAGEMENT—INTERIOR & EXTERIOR
Slab/Wall Interior Drain, Rigid FoamDOWNLOAD: PDF | DWG
Rubble Wall, Interior DrainDOWNLOAD: PDF | DWG
Exterior Foundation Flashing—RubberDOWNLOAD: PDF | DWG
Exterior Foundation Flashing—PlasticDOWNLOAD: PDF | DWG
BAND JOIST
Rigid Foam RetrofitDOWNLOAD: PDF | DWG
Spray Foam RetrofitDOWNLOAD: PDF | DWG
GBA Pro members get full access to the Construction Detail Library.
Join Now.
COVERING A DIRT FLOOR
Concrete Wall, Dirt Floor
Polyethylene CoverDOWNLOAD: PDF | DWG
Interior ColumnDOWNLOAD: PDF | DWG
CRAWLSPACE w/ CONCRETE STEM WALL
Concrete Wall, Interior Rigid Foam
3/4-in. Rigid FoamDOWNLOAD: PDF | DWG
1-in. Rigid FoamDOWNLOAD: PDF | DWG
1 1/2-in. Rigid FoamDOWNLOAD: PDF | DWG
Concrete Wall, Exterior Rigid Foam
BECOME A MEMBER AND GET FULL ACCESS TO THESE DETAIL DRAWINGS
CRAWLSPACE w/ BLOCK STEMWALL
CMU Wall, Interior Rigid Foam
CMU Wall, Exterior Rigid Foam
Detail Packages that can make old houses energy efficient:
BECOME A MEMBER AND GET FULL ACCESS TO GREEN BUILDING ADVISOR
  • Detail Library
    Building Plans for Energy-Efficient and Healthful Kitchens and Bathrooms
    ###How to Remodel Kitchens or Bathrooms: details that will help you stop air leaks and insulate exterior walls behind tubs and showers, seal penetrations in the ceiling from recessed lights,…
  • Detail Library
    Building Details for a Deep-Energy Retrofit
    How to upgrade windows, walls, roofs, and basements with spray foam, rigid foam, blown-in cellulose, and other insulation types 11 Detail drawings in this Deep-Energy Retrofit collection: ROOF INSULATION RETROFIT…
  • Detail Library
    Building Plans for Advanced Framing
    How to Add Energy Efficiency to Rough Framing: Reduce thermal bridging with less lumber and more insulation — energy efficiency and comfort are bonuses ADVANCED FRAMING DETAILS IN THIS PACKAGE:…
  • Detail Library
    Building Plans for Energy Efficient Basement Remodeling
    How to Finish a Basement for Energy Efficiency and Comfort: Details for a basement that insulates against water, weather, and radon gas. There are 23 construction drawings in this basement…
