Interior poly vapor barrier
I’m considering fiber cement siding and drainable house wrap for my 1994 house in coastal South Carolina. In 94, the builder installed a poly vapor barrier between the wallboard and the studs throughout the house. Based on my reading on this great website, I believe the wall assembly, which is OSB, covered by a disintegrating house wrap and vinyl siding, must dry to the outside. I would like to use a low perm house wrap due to the hot, humid climate, but I’m concerned that would affect the ability to dry to the outside.
Any insight would be appreciated.
lad,
The big worry with interior poly in warm, humid climates is during the cooling season when it becomes a wrong side vapour-barrier, and can have moisture condense on it.
OSB is about 2 perms when dry and opens up to about 12 perms when damp, so it will probably be what limits drying to the outside, even with a low perm WRB.
Thanks Malcom. We recently opened a couple of walls during a renovation and the osb was fine. So I guess the wrb should not be an issue
lad,
That's good news. I think you will be fine.
