Minisplit floor unit airflow direction
Hello GBA,
I have a mitsubishi floor unit mounted inset into a wall. It is used primarily for heating. My issue is that it blows straight out or a bit up, and often onto people near it. It would be far better if it blew towards the ground, like a wall unit would. I wish I could flip the whole unit upside down. Would it be possible to get a supply diffuser to angle airflow down? I’m afraid it may cause a short circuit and just cycle the same air, but hopefully on high setting it would throw it far enough out. Failing that, what if I get grills to at least spread it to the sides (the builtin ones don’t do much). Any suggestions? Thanks!
