Protecto LWM200 vs TK-Hydromax 2002 VOC Is there a real difference?
We are currently deciding between these products for a foundation membrane. Has anyone had experience with either of these and would you recommend one over the other? Some back ground info: our area is a wet area so the home is being built up, with one of these membrane being applied, then 2’ foam for exterior insulation, then the delta-ms dimple mat.
