Range vent hood blower – troubleshooting
bsawers | Posted in Mechanicals on
Ten years ago, this house by renovated by a previous owner. The range hood was made by GE, although the blower was made by Best. According to GE, it typically moves 390 cfm at max power.
We bought the house 3 years ago. Until recently, the range hood seemed to do a good job. Now, it barely moves air even at the highest setting.
I checked the dampers just above the blower and the damper to the outside. Both seem to move freely. I can’t see any obstructions, although I can’t see the entire 18 inches from blower to exit.
I am getting conflicting advice of whether the fan could be worn out without other symptoms. The fan seems to make the same amount of noise as before. Some people say that things last about 10 years now; others say that if the fan motor was worn out, I would hear it.
One suggestion was removing grease from fan blades. While it’s not clean, the grease build-up hardly seems enough to justify the collapse in function.
I plan to clean the fan blades today. But I would still like to know whether the blower motor might be worn out and how to know (without a device for testing CFM).
Lastly, I would like to hear people’s thoughts on spending $350 to replace the blower or spending $1800 to replace the entire range hood.
  1. GBA Editor
    RANDY WILLIAMS | | #1
    The only way to verify air flow is with an air measurement tool. There are several that can work ranging from under $100 to more than $3,000. An easy test to confirm if air is moving is by using a piece of tissue or with smoke. With the fan operating, place a tissue or some type of smoke generator (a cigarette or candle that produces some smoke) in the air stream. If it flows towards the fan, you are at least moving some air. Another check is to watch the outside damper with the fan in operation. If the damper remains closed, the fan is not moving air.
    One issue may be the fan blade is stripped or loose where it connects to the motor. The motor would make the same noise, but the fan either doesn't turn or turns at a slower rate as it spins on the motor shaft.
    If the fan and fan motor are able to be replaced with identical units, I'd replace them instead of purchasing a whole new range hood.
    Randy
