Sealing duct boots
When sealing duct boots to the ceiling, is it better to do it from the attic side? Or seal everything to the drywall from inside the home? Or does it not matter?
I'm working on an HVAC update now, and planning on doing both. I've asked my HVAC contractor to seal that can-to-drywall connection when he installs the actual ducts, and he says he will use mastic tape to create the best seal possible from the attic side. I also plan on finishing that connection with metal tape of my own from the interior. It will all be hidden by the register cover, ultimately, but it's another piece of mind to keep the attic in the attic.
It's worth nothing that working overhead on a ceiling is always a fiasco, and if you have access via the attic — and it's not hot — that is probably the simpler way. Working "down" is much more comfortably, physically.
Note the smart move is to make room inside your conditioned space for your HVAC equipment and ductwork. If you do any leakage is almost irrelevant as it will stay inside the conditioned space.
HVAC in a vented attic is likely to require 30-50% more energy to operate.
HVAC in a conditioned attic is likely to require 25-40% more energy to operate.
