Wall assembly w rigid foam, sheathing and vinyl siding
AB_AWW
| Posted in Green Building Techniques on
Looking for a detail that shows side wall detail with rigid foam, sheathing, barriers and vinyl siding.
Thanks
Glenn
Hi Glen,
I would check with the manufacturer of the vinyl siding you are looking to use. Often, they have details in their installation instructions with the requirements for installing their product over continuous exterior insulation. Here is an installation guide, but I would check specifically with the manufacturer you are planning to use.
https://polymericexteriors.org/wp-content/uploads/2024/04/04.12.2024_Electronicverson_PoylmericCladdingOverContinuousInsulation_March202495.pdf
Randy
