Window frame to window buck sealing
Out of interest:
is the use of expanding foam strip known in the states? It would simplify installation.
Like that one:
Buy VKP Trio 600 sealing tape standard online | WÜRTH
The foam has a different pore size and configuration across the width, so is watertight and permeable outside and airtight and a vapor retarder inside. Will stay flexible and continues to maintain sealing function.
I reckon that this should simplify the installation of inni windows and be a second layer of defense also for outer windows.
Yes, a brand available here is Hannoband Expanding Sealant Tape.
Ah - ok. Thanks for the info. As an imported product this seems to be a niche application.
Contiga also makes a tape like that, can't remember the product name.
