Expert Exchange Q&A
Cutting channels in EXP insulation board to mimic a dimple mat for cement basement floor: Will this work?
I am looking for advice on the best way to reduce humidity seeping up from my unfinished basement floor of my large, Second Empire Victorian house in Western Massachusetts that…
Cold climate slab on grade
hello all, building a home in climate zone six a, relatively high water table, building slab on grade because we cannot dig a basement. my Builder wants to use precast…
Cottage HVAC design approach
We are building a 1,300 sq.ft. cottage and would like expert advice on the best strategy to heat and cool It is a one story home with a low crawl…
European Windows- OKNOPLAST
Hello there. I am a builder of high-performance homes in Minneapolis area. I have developed 5 Passive homes in the last 3 years and used Access Windows out of Canada.…
Open cell spray foam—water damage
Hi everyone, I could use some guidance. I’ve been dealing with serious indoor air quality issues in my custom-built home since day one. The house is two years old,…
Fire rating increase with Denslgass over OSB – am I in for a drying/perm problem?
In planning a wall assembly on a new home, we're tasked with adding some fire resistance to the wall assembly while not significantly expanding the wall thickness. By adding a…
Climate zones 6,7, & 8 – Attic kneewalls encased in spray foam. Help needed
Hello everyone. I inspect homes and produce residential construction related educational content in Alaska's climate zone 8. Occasionally I come across situations that I'd be very appreciative of input. This…
small office cabin hydronic heating with air-to-water heat pump
Hi,I am building a 420 ft2 home office cabin that will also serve as a sleeping cabin when we have guests in our main house. In the main house I…
Can cross-wiring in a Mitsubishi multi-split system cause evaporator coil failure?
I'm seeking expert opinions on whether a cross-wiring installation error in a Mitsubishi multi-split system could lead to evaporator coil failure. Here are the key details:1. System: Mitsubishi multi-split with…
Consolidating multiple exhaust vents
We're preparing to begin our mechanical rough in on a new construction home in climate zone 6a. Between make-up air and exhaust, we will need 7 penetrations, and this is…
