Does closed foam insulation need to be enclosed
I have finished my basement and have used a closed cell insulation against all cement walls. I have sheet rocked all living and bathroom areas. Do I need to sheet rock over the foam in the storage areas as well?
If you have exposed foam, I believe that is against code in most areas. Check locally. Either way, I would never leave foam exposed.
