Airtightness and mechanical ventilation
igou
| Posted in PassivHaus on
What is the limit point, in terms of airtightness, that a residential retrofit needs mechanical ventilation (with heat recovery)?
Ilais,
There are too many variables (and too many unresolved technical disputes) to answer your question with a simple answer. For more information on this issue, I suggest that you read the following article, as well as the comments posted below the article: Ventilation Requirements for Weatherized Homes.
The simple answer is that you need a mechanical ventilation system if you see condensation on the interior of your windows during the winter or if your house smells stuffy.
