guest-blogsheader image
0 Helpful?
What Will We Do With All Those Solar Panels When Their Useful Life Is Over?
As solar power booms, businesses are exploring ways to ensure valuable components don’t end up in landfills
Posted on Apr 24 2018 by Nate Berg
This post originally appeared at Ensia.
Solar power is having its hockey stick moment. Since the early 2000s, the amount of solar panels being installed worldwide has been growing exponentially, and it’s expected to continue to do so for decades. By the end of 2015, an estimated 222 gigawatts worth of solar energy had been installed worldwide. According to a recent report from the International Renewable Energy Agency, that number could reach 4,500 GW by 2050.
But the solar panels generating that power don’t last forever. The industry standard life span is about 25 to 30 years, and that means that some of the panels installed at the early end of the current boom aren’t long from being retired. And each passing year, more and more will be pulled from service — glass and metal photovoltaic(PV) Generation of electricity directly from sunlight. A photovoltaic cell has no moving parts; electrons are energized by sunlight and result in current flow. modules that will soon start adding up to millions, and then tens of millions of metric tons of material.
“It’s not too far off that those are going to be coming off line, and we’re going to have a waste management issue,” says Garvin Heath, a senior scientist at the National Renewable Energy Laboratory and a solar power expert. “It’s fair to say that it’s starting to become more widely recognized as an issue that we’re going to need to start working on pretty soon.”
The solution many are looking to is recycling. But the ability to handle the coming flow of PV modules is not yet sufficient. “There’s some infrastructure,” Heath says. “I wouldn’t say it’s especially well established at this point.”
Part of the problem is that solar panels are complicated to recycle. They’re made of many materials, some hazardous, and assembled with adhesives and sealants that make breaking them apart challenging.
“The longevity of these panels, the way they’re put together and how they make them make it inherently difficult to, to use a term, de-manufacture,” says Mark Robards, director of special projects for ECS Refining, one of the largest electronics recyclers in the U.S. The panels are torn apart mechanically and broken down with acids to separate out the crystalline silicon, the semiconducting material used by most photovoltaic manufacturers. Heat systems are used to burn up the adhesives that bind them to their armatures, and acidic hydro-metallurgical systems are used to separate precious metals.
Robards says nearly 75% of the material that gets separated out is glass, which is easy to recycle into new products but also has a very low resale value. Not only that, but what’s available to recycle is something of a moving target. As solar panel technology improves, manufacturers are slowly finding ways around using components that would have value to recyclers, like copper and silver.
“So the underlying commodity value of these things keeps going down,” Robards says. The less value a recycler can extract, the less incentive there is to recycle.
Despite the challenges, ECS has been ramping up its photovoltaic recycling capacity. “It’s a semi-decent growth area these next few years but exploding about 2020 and beyond,” Robards says, anticipating the millions of metric tons of panels expected to come off-line.
Training and cost
Until there’s a steady stream it will be hard for recyclers to focus more of their business on solar panels. In order to make sure they’re ready, though, the solar industry is creating programs to train commercial recycling companies to understand what’s in manufacturers’ products and how to break them down, according to Evelyn Butler, senior director of codes and standards for the Solar Energy Industries Association, a trade group representing solar power companies and photovoltaic manufacturers.
Butler says the group is also working with recyclers to share data about what components and materials they’re processing so that they can start to track and forecast their waste.
A recycling facility gives photovoltaic panel producer First Solar a way to extract components from defunct solar panels for eventual reuse. [Photo credit: First Solar]
“We’re still pretty early on in the process, but we’re hoping that in five or 10 years we’ll be able to provide industry data on that,” she says.
Some photovoltaic companies are leading their own recycling efforts. First Solar, one of the largest photovoltaic providers, has long offered recycling for its products. Over the years, its recycling process has gradually improved, according to Sukhwant Raju, the company’s director of recycling operations.
“Our company has over 100 million modules out installed, but they may be another 10 to 15 years away from getting to their end-of-life stage,” he says. “As the time passes, our technology cost is coming down, but at the same time, the volume of the scrap increases. So that gives us economies of scale.”
The company’s long-term goal, Raju says, is to make sure the process is cheap and efficient enough to deal with the expected surge of decommissioned panels.
The total cost has to be so low that nobody has to think about any other option than to recycle. “Within the last eight years I’ve seen tremendous reduction in that cost,” he says.
In conjunction with better recycling methods, the company’s panels are designed to be conducive to recycling. Up to 90% of the glass and semiconductor material in its decommissioned panels can be reused in new panels or other glass products.
Laws and regulations
In the U.S., most of this progress is happening without the guidance of regulations. There is currently no federal standard or requirement for end-of-life management of photovoltaic panels that don’t meet the standard for hazardous waste — and they they typically do not. No major state rules have been established for these non-hazardous wastes, either.
Heath at the National Renewable Energy Laboratory notes that the state of Washington passed legislation last year requiring manufacturers to finance the recovery and recycling of panels sold in the state. It’s the most advanced legislation focusing on solar panel recycling so far, but the regulations aren’t expected to be fully implemented until 2021. Heath also notes that Washington is not one of the largest solar-dependent states. In California, which is a major solar state, legislation is still likely years away.
Outside of the U.S., though, there is a model to follow. The European Union’s Waste Electrical and Electronic Equipment Directive requires producers to finance end-of-life treatment of solar panels sold in Europe.
Similar federal regulations in the U.S. are unlikely in the near future, according to First Solar’s Raju. But given the massive amount of solar panels expected to be falling out of service in the coming decades, experts predict that more encompassing regulations are inevitable.
“I think it is just a matter of time,” says Raju. “I would personally be very surprised if 10 years down the road we don’t have a similar program in place.”
Nate Berg covers cities, science, and design. He is based in Los Angeles.
Tags: , ,
Image Credits:
  1. Image #1: Dave Goodman via Flickr
1.
Apr 25, 2018 12:51 AM ET
Panels from the 70s are still in use...
by Will Campbell
I don't think this is as big a problem as the author would have us believe.
First, panels typically last for much longer than their nominal warranty period, which normally refers to a guaranteed output. So a panel that is 30 years old in 2040 but installed in 2010 will likely still have a useful life- it just won't be making nameplate power.
Second, there is already a secondary market right now for used panels. If you have a surplus of space and not much money, these older panels can often be used to create plenty of power- you just need slightly more of them compared to new ones. I would expect the secondary market to expand, with sales to developing countries, lower-income consumers, green buyers (what's more green than a recycled PV panel?), and anyone else who can't afford the (ever decreasing) cost of new panels.
In other words, though the cost to "unmanufacture" the panels might be high, the impetus for doing so will likely be low.
Become a GBA PRO!
