Wind-Generated Power
At the Right Site, Wind Is Cheaper than Photovoltaic
Read the full article by subscribing to GBA Pro for valuable how-to information and insights about
Wind-Generated Power, including:
  • Design and build strategies
  • Necessary codes
  • Application how-tos
  • Using materials
Wind can provide a sizable portion of energy needs
As a rule of thumb, a building site should have an average wind speed of 10 mph to make the installation of a turbine worthwhile. At wind speeds much below this the turbine cuts out and no power is generated.
The U.S. Department of Energy has published a map showing average wind speeds that can be useful in calculating the potential of a site.
Wind conditions are highly localized. Especially hilly areas may require site-specific data collection to make sure it’s not ...
Tags: , ,
