Article
The Stay-Dry, No-Mold Finished Basement
When you remodel a basement, moisture matters
Plastic vapor barriers and fiberglass insulation are not the best choices for finishing a basement because they can trap moisture and promote rot. This article features a basement where rigid foam sealed with tape and two layers of plywood on the floor create a comfortable space. A sidebar calls attention to the importance of fire safety and air quality when finishing basements.
The Stay-Dry, No Mold Finished Basement_FHB169.pdf
