Helpful? 0
A Passivhaus Project in D.C. Nears Completion
Construction began last summer, and now this luxury home is getting ready to go on the market and become certified by Passive House Institute U.S.
Posted on Apr 28 2011 by Richard Defendorf
UPDATED on May 1, 2011, to change the description of the exterior-wall insulation layers outside the SIPs to EPS (expanded polystyrene) from XPS (extruded polystyrene).
In October, when we last checked in on the New American Foursquare, a Passivhaus project in Bethesda, Maryland, the foundation was already in the ground. Passive House Institute U.S. director Katrin Klingenberg had stopped by the jobsite an offered a suggestion for airsealing the foundation perimeter, and a crew of specialists in structural-insulated-panel installation would soon get to work putting up exterior walls.
The project is now in the finish-work stage and has been put through a couple of preliminary blower-door tests to track down air leaks and affirm that the house is sufficiently airtight. The first test showed about 0.67 air changes per hour at 50 Pascal pressure difference. The second test, conducted before drywall and trim were installed, showed 0.59 ACH, which meets the Passivhaus airtightness requirement.
A prototype and suite of plans for replicas
At 4,318 sq. ft., with five bedrooms, four and a half baths, and a finished attic and basement, this house is being presented by the project principals – O’Neill Development and Peabody Architects – as a prototype that can be replicated in several sizes and less-costly configurations. The strategy is to offer plans for American foursquare homes in sizes ranging from 2,400 to 4,400 sq. ft., and homes built in a Craftsman cottage style from 1,500 to 2,500 sq. ft.
The New American Foursquare prototype is located in a Bethesda neighborhood that, even by the standards of the Washington, D.C. metro area, is relatively pricy. The home's listing price is expected to be $1,688,000, but the partners hope to accommodate far smaller budgets with many of the replicas.
SIPs and “outsulation”
The home's exterior walls are built with 8-in. InsulSpan SIPs covered on the exterior with two staggered layers of expanded polystyrene (1 3/4-in. thickness total), bringing the total thermal resistance of the wall assembly to R-36. The foam sheets were covered with Tyvek housewrap and vertical furring strips to create a rainscreen; the siding is HardiePlank fiber cement.
The roof was constructed with 12-in. SIPs, with standard asphalt shingles over felt, for R-45 thermal resistance. Foundation walls are insulated to R-44 with 4 in. of EPS on the exterior and 5.5 in. of fiberglass on the interior, while the concrete slab, at R-20, has 4 in. of EPS with a vapor barrier underneath.
Windows on this project are Thermotech triple-glazed units with insulated sashes and frames, and motorized awnings have been installed on the west wall of the home. (There are roof and porch overhangs on the south wall.)
Mechanicals
The house is equipped with two Zehnder ComfoAir 350 energy-recovery ventilators, one for the attic and second floor, the other for the basement and first floor. A hot-water line from the home’s gas boiler runs to a heat exchanger downstream of each ERV unit. The boiler also supplies hot water to a Weissmann insulated tank with an integral solar heat exchanger, although installation of solar collectors will be up to the homeowner.
A 36,000 BTU Mitsubishi ductless minisplit air-source heat pump will assist with cooling and dehumidification.
Bringing the home to the Passivhaus performance standard added 8% to the project’s construction costs, according to the project partners. The annual energy bill is expected to be about $2,400, although the usage habits of the occupants will obviously come into play. Still, architect David Peabody points out that only about $600 – or 25% – of the estimated annual energy bill is likely to be for heating and cooling.
Tags: , , , , , , ,
Image Credits:
  1. Peabody Architects and O’Neill Construction
1.
Sun, 05/01/2011 - 15:09
Exterior insulation correction
by Al Cobb
Helpful? 1
Richard,
The exterior insulation was EPS not XPS. The staggered sheets were a standard 1pcf density while the layer behind the window wrap was a 2pcf density.
The blower door numbers were personally very disappointing. However, when you look at the fact that three of the Thermotech units were missing glazing (plywood insert waiting on delivery), and the ill-fitting doors (light can be seen coming through the door seals) I'll have to wait patiently for the final test.
2.
Sun, 05/01/2011 - 18:29
Thank you, Al
Helpful? 0
I very much appreciate the follow-up. The correction has been noted and applied to the text.
Become a GBA PRO!
