How to Calculate the Value of Energy Improvements
With so many variables at play, how does one measure energy savings when justifying the cost of retrofit measures?
Okay, we installed the 95% AFUE furnace — are we saving any money? After implementing an energy-efficiency measure in your home, is there any accurate way for you to calculate your energy savings?
Adding more insulation, replacing an inefficient furnace, or performing air-sealing measures are oft-recommended strategies for lowering energy consumption and saving money.
Aaron Vander Meulen puts his finger on a key issue, however, when he wonders whether there is a way of determining exactly how much money improvements such as these will save.
"Anecdotally, my parents upgraded to a 95% furnace last year, and are seeing the savings, but it would have to be compared to the [heating degree days] for each year, correct? And even at that it's something of a crap shoot since they have a gas water heater as well? One would need to monitor volume of gas at the furnace, correct? is there any sensor for this?"
His question points to the complexity of this seemingly simple question and is the subject of this week's Q&A Spotlight.
Two points of view
The simple answer to your question, says Michael Blasnik, is no.
"There is no way to figure out the exact savings from a retrofit because we don't have a perfect parallel version of the world handy where everything else was the same except for the retrofit," he writes.
RELATED MULTIMEDIA
What Is a Deep Energy Retrofit?
Home Energy Monitoring, Part 1: Knowledge is Power
RELATED ARTICLES
Remodel Project: Deep Energy Retrofit
Best Construction Details for Deep Energy Retrofits
Blasnik suggests Meulen can get a "fairly good idea" of savings by analyzing energy and weather data, but he adds, "You can't control for everything in any given home — differences in occupancy, behavior, non-temperature weather (wind, solar gain), and other changes in the building and equipment can all affect the observed savings... By analyzing the energy use of large groups of homes you can learn a lot more about retrofit impacts, but the findings in any one home will always be suspect."
John Klingel, however, is voting an "emphatic" yes to Meulen's question.
"Not down to the gnat's butt, as you will never get 'exact' for anything, anywhere, anyhow," Klingel says. "But if you can assume that whoever will live there for the next few years will behave like they did in the prior few years, and the weather will generally be what it has been, then all the variables are gone. Is that a fair assumption?
"Well, what other options do you have?" Klingel writes. "Does it matter if you are off 5%? That's your call. Just do a heat analysis with insulation A and insulation B, or whatever A and B you want to compare, and you've got a pretty good handle on it. I don't see any issues with that at all."
A 'self fulfilling prophecy?'
The problem with your approach, Blasnik tells Klingel, is that it becomes a self-fulfilling prophecy. "If energy savings don't meet expectations, you'll be able to come up with a reason that explains it, and if savings do meet your expectations you'll be convinced you had it figured out."
But in general, neither the weather nor the habits of the occupants will be the same from year to year. "The differences won't usually matter that much if you are expecting energy savings of 40% or so, but they will matter quite a bit if you are expecting savings of 20% or less," Blasnik says. "Energy use tends to change from year to year with a standard deviation of perhaps 10%. Since you are only looking at one house, it limits how strong a conclusion you can make regardless of the results."
Klingel sees Blasnik's point: namely, that doubling the amount of insulation in a house doesn't guarantee that next winter's energy bills will be cut in half.
"Certainly, Nature is going to vary and confound/camouflage your results; that's Nature," he writes. "But, all that aside, you've still got your savings tucked into that variability. It's still there, whether it shows its face or not. That was my point: The savings will exist, but not necessarily be recognizable year to year. Heat loss is heat loss. Fuel usage, and subsequent variability, is another issue."
Should renovators promise results?
These variables raise an interesting question, as suggested by David Meiland. "So," he asks, "should someone doing an audit for an individual homeowner make projections regarding energy use before and after improvements? Give them payback periods for improvements?"
"Consulting professionals of many stripes do this all the time, as do contractors and installers wanting to make a sale," says James Morgan. "Whether they SHOULD is more a question of ethics than technology, given that nearly all have motivation to err on the optimistic side, sometimes wildly.
"I have known energy consultants go so far as to guarantee performance," he adds, "but (given the multiple variables Michael mentions) this did not prove a sustainable business model."
Blasnik doesn't see a problem with providing an estimate of energy savings that will result from a retrofit, providing the contractor has a "reasonable method" behind him. "That's not the same thing as telling people what their bills will be next year," he says. "The savings are how much less energy they use compared to what they would have used if they didn't do the retrofit."
"For example, if a household's heating energy use was $1,000 last year and you install retrofits to reduce that by about $200, that doesn't mean their energy use will be $800 next year," Blasnik adds. "It could be that they just had a baby and their heating use would have gone up to $1,100 but instead it's now $900 — they actually saved $200 but their bills only went down by $100.
"In any given home we don't really know how the energy use would have changed without the retrofit, but across large groups of homes we can generally confirm the impacts of retrofits using evaluation methods."
Our expert's opinion
Here's what Peter Yost, GBA's technical director, had to say:
I have yet to meet a high performance residential remodeler who is happy with an energy modeling program for existing homes. Michael Blasnik has done a lot of great work in this area, demonstrating how frustrating it can be to try to predict the impact of various strategies using existing modeling tools.
That said, existing homes give us a starting point lacking in new homes: utility bills. I have used the Lawrence Berkeley National Laboratory Home Energy Saver, , a Web-based tool. The detailed long version requires about 45 minutes to an hour of data entry, and I've come within $100 of my total annual energy bills on our own home — pretty amazing. So, we are making progress in this area.
But to me the most promising work is in the area of energy bill guarantee programs. For the longest time, I have been telling folks that there are no programs that do energy bill guarantees for remodeled homes — just new ones:
- Bigelow Homes (the first in the country; they've been doing it for more than 20 years now)
- Artistic Homes
- Comfort Home
- Tucson Electric Power
But just a year or so ago, one of my online students in a Boston Architectural College course corrected me: there are in fact TWO programs that guarantee energy bills for gut rehabs or substantial energy improvements: Tucson Electric Power and Masco's WellHome.
I don’t know what sort of energy modeling software each program uses, but the basic approach of all of these programs is to guarantee just the space conditioning loads by using the shoulder seasons to average out a base load (the base load being DHW, appliances, lighting, and plug load).
But clearly, taking into account the vagaries of any existing home’s unique energy performance and occupant behaviors can be at least partially deciphered by using the “institutional memory” of the home built in to the utility bill history.
Added Note by Author (4-7-2011):
Can't believe I missed this one, but Mike Rogers of Green Homes America reminded me that they too, do an energy bill guarantee on their retrofits and have for several years.
Image Credits:
- Goodman
Mon, 03/07/2011 - 11:13
Energy Improvements
by Grant Dorris
I agree that calculating energy savings on an energy retrofit/upgrade is difficult - especially when there are so many specialty contractors making exaggerated claims. Homeowners will seldom see substantial savings from a singular improvement. Energy improvement is a package deal - and I rarely see package deals being presented to homeowners. Even if they were, I think the average homeowner, in a non-subsidized community, would balk at the cost. Managing expectations is the best thing we can do for homeowners. I always calculate base loads off of their historical energy bills and try to explain potential savings from that point. For example, replacing that 15 year old hvac equipment could reduce your heating costs X%.
Occupant behavior is the wild card. Recent studies seem to indicate that people who undertake energy efficiency measures in their home do so to have the ability to use more energy. I can only speak for myself, but I made a point to monitor my own behavior very closely from October 2009 to present - without performing any energy improvements. I have been able to reduce my total energy consumption by about 25% without discomfort. This has not translated into a 25% reduction in my energy bills, as energy prices have risen. This is one way we can manage customer expectations by explaining the reality of the situation.
On a related note, I think it would be extremely effective to have an in-home energy/water monitoring device that turned units into dollars - and sent that information to an iPad sized monitor that was stuck to the refrigerator door. I would think that displaying real-time, out-of-pocket expense would go a long way to changing occupant behavior.
Mon, 03/07/2011 - 12:56
question for Grant
by Michael Blasnik
Could you share references to those recent studies? I'd love to see their methods and data.
Mon, 03/07/2011 - 15:18
Answer for Michael
by Grant Dorris
Michael,
That came from a recently published report from the Shelton Group - the Energy Pulse. Unfortunately, I cannot provide you with direct information as the reports are priced way above my current budget. I did have the opportunity to see some of their findings and this part really stuck out:
In our Energy Pulse study the second best message to move a consumer to spend $4,000 on energy-efficient home improvements was “I’d be able to set my thermostat to a more comfortable setting without paying more.” We’re hearing it in focus groups, too — that consumers want to buy more energy efficient products so they have license to actually use more energy.
The Shelton Group's website is: http://www.sheltongroupinc.com/
Mon, 03/07/2011 - 16:35
reply to Grant
by Michael Blasnik
So it's people saying they'd like to turn up their thermostats -- is that "data"? What fraction of people said this? How big of an average increase in indoor temperatures do you really think occurs?
I think most people are keeping the thermostat where they want to in order to be comfortable. I've got at least as good alternative story -- people in less drafty and better insulated houses are able to turn their thermostats down and feel just as comfortable.
The limited real world data that I've seen -- measured temperatures in people's homes -- has not really supported either theory much. It seems that there is little net change on average with about equal numbers increasing and decreasing temperatures.
Wed, 03/09/2011 - 15:38
Consumers need to understand
by Trish Holder
Consumers need to understand that this is a very complex question. I write extensively in the commercial and institutional industry about facilities that spend millions on efficiency upgrades, but can never supply me with hard data about how much they are saving. And they have sophisticated BMS systems and engineers on staff.
I wish it wasn't always about the dollars. I wish that sometimes the conversation would be about saving energy for saving energy sake.
Thu, 03/10/2011 - 10:43
Because it's the right thing to do.
by James Morgan
"I wish it wasn't always about the dollars. I wish that sometimes the conversation would be about saving energy for saving energy sake."
Amen, Trish.
Thu, 03/10/2011 - 10:44
Macro level
by David Briscoe
When I remodeled a 1954 ranch a few years ago I added square footage, sealed & insulated, & changed from gas heat to an electric GSHP. After spending hours with a spreadsheet and years worth of electric & gas bills I recognized that like many other enthusiastic green product marketers I'd gotten sucked in to thinking I could compare apples to oranges in an effort to show energy use improvements.
So I stepped back to a more macro level - one which is simple, understandable & meaningful to my clients: Combined gas & electric costs in the month of January (in Minnesota) went from $.29/sf to &.09/sf, for the same number of occupants ....and Minnesota Januarys are pretty much the same year-to-year.
In my opinion this is a realistic & truthful measure
Thu, 03/10/2011 - 21:40
Therms and kWh's
by Doug McEvers
The best way to predict energy savings for a proposed energy retrofit is to review energy bills for a given residence. If you are fortunate enough to have metered natural gas, figuring out the heating portion of the yearly bill is easy. The baseline months of June, July and August will tell you your gas usage for hot water, clothes drying and cooking. Add the total therms used for these 3 months and divide by 3 to get your base monthly gas use. This base monthly usage X 12 months gives you the non heating portion of your gas bill, the rest is the heating load.
With this information you can plug in yearly heating degree days (hdd) to get an idea of the current building efficiency. I like to use hdd per therm. This will remain constant regardless of the severity of the winter because of the correlation between energy used and the heating degree days for the period. The lowest hdd per therm will be in December and as the daylight increases so will your solar gain and hdd per therm. Furnace efficiency comes into play and if the efficiency is known you can multiply the annual heating energy usage by it to determine the actual annual heat loss for the building. Heating seasons vary so to compare year over year you will need to normalize the energy used as a percentage of the normal hdd.
The next step is to determine the heat loss for a building expressed in Btu's per degree F. To do this you need to break the building down into elements with square footages for each. The elements would be walls, ceilings, windows, foundation and the like. Determine the U value for each X the area X 24 hours X normal hdd for the heat loss for each element in Btu's. The total of all of these will be your annual heat loss in Btu's plus infiltration heat loss. The difference between the elemental heat loss and the actual energy used will be the infiltration heat loss, we will leave solar gain out of the equation for now.
If you are considering an energy improvement to your house I would recommend a blower door test and thermal imaging to see the current picture of the building. Air infiltration can be a large part of the annual energy used and has everything to do with comfort. To improve the efficiency of any building you will need to reduce air leakage and improve the thermal envelope. With the home broken down into elements and an annual energy usage assigned to each you can run some improvement scenarios to see where the best return on investment will be.
Thu, 03/10/2011 - 22:47
energy data
by Joseph Ford
This is primarily a reply to Trish Holder: The situation you describe of not having detailed energy use data is pretty much the norm. My experience isn't vast, but what I have seen is that energy modeling is usually not done except when a project is pursuing some sort of certification, e.g..: LEED. Ergo, there's no baseline energy simulation. There are plenty of baselines out there one can compare one's building to, but it's not the same as a simulation of your exact facility.
Similarly, even when you look at new construction with a nice new physical plant and BAS, the sensors and systems required for detailed measurement of energy use typically aren't standard equipment. These components are pricey, and most building owners find them cost prohibitive.
I've found a good resource in the DOE/EERE's High Performance Buildings Database. It provides many case studies, a lot of which include information on simulated vs. actual energy use. For more detailed reading, I would also recommend searching EERE for Zero Energy Building case studies. There are very few of these buildings, but by definition they have comprehensive measurement and verification systems for energy use. The studies are able to describe precisely what works and doesn't and exactly what it means in terms of energy.
Fri, 03/11/2011 - 02:31
Home Energy Saver
by John Klingel
The Home Energy Saver program linked to above is nice, and I am glad it is available, but it is extremely limited for anyone considering building a well insulated house in a cold climate. The only R value for under a slab is 5. Hmmm. I hope the DOE upgrades the program. I appreciate it being there, but don't understand the R value constraints in its present form. Dang.
Thu, 03/17/2011 - 00:37
Unfortunate Tendencies
by Eric Novotny
While I certainly appreciate the desire to measure the success of an improvement in terms of ROI, most of our customer's efforts are aimed at being better stewards of their resources and the correction of comfort issues.
A door that is left cracked open for a few hours can wreck an entire week's worth of improvement.
Find me a home with children and I will show you an uncontrollable set of variables.
Google
Yahoo
Facebook
Technorati
Reddit
Delicious
Digg
StumbleUpon
Comments
